Where Are the High Gain Amps?
Hey yall,
Where are the high gain amplifiers in the OpenBCI ? I looked for op amps or instrumentation amps on the V3 32 bit schematic.
Did you guys forget them? ; )
Thanx.
    edited August 2014
    The ADS1299 uses a Delta Sigma analog to digital converter, which has the big advantage of not requiring a lot of external components such as preamps or filtering. It does have a good onboard Bias generation, which cancels out most 60 Hz line interference, as well as other common mode signals.
  • Hi wjcroft,
    Thank you for that info. I see from the description at the top of the ADS1299 datasheet that it was designed for EEG.
    I'm still amazed though, that it works without preamps with microvolt input signals. Just eerie. Thanks.
  • Actually the ADS1299 integrates the pre-amps. Each channel has one. The gain is programmable and goes up to 24x. Also its high resolution of 24-bit means you can still see signals much, much smaller than full-scale.
    Ferdinand
  • Ferdinand,
    A gain of 24 is not enough for microvolt (millionths of a volt) level inputs. These preamp circuits are not high-gain. Even just to use the 8 least significant bits, the input would need to be amplified around 400 times at least,
    (1 volt/1 x 10^-6 volts) / 2^8 = 390.625  assuming 10 microvolt input levels and 1 volt outputs. The Delta Sigma technology is the key. I don't totally understand how that works; seems to be a lot of mathematically based theory involved.
  • Gyorgy,
    let's assume you use the integrated 2.4 V reference, which gives you a full-scale input of 4.8 Vp-p (+-2.4 V). Setting the gain to 24x results in full-scale of 200 mVp-p. Now the LSB is approx. 12 nV. (200 mVp-p / 2^24). An input of 10 uVp-p would result in a code of approx. 833. You would end up with a resolution of a little less than 10-bit for your signal.
    Delta sigmas are highly over-sampled 1-bit ADCs. Applying a digital decimation filter to this low resolution, high speed bit stream gives you a higher resolution, lower speed bit stream. This is nice as the actual sample rate of the converter is very high, which means anti-aliasing filters are much easier to design (single pole filters suffice in many cases).
  • Hi all,
    So how many bits of the 24 in the ADC does the OpenBCI get?
    Thanks
  • Hi Gyorgy,
    The short answer is that you "get" at 24 bits.  I believe that your question is actually about how many of the bits are real and how many are noise.  I, too, wanted to understand the self-noise of the OpenBCI system when I first started using it.  So, while I have not yet measured the self-noise of the new V3 board, I did measure the self-noise of the V2 board.  You can see my discussion and data here:
    If you are especially interested in the very low frequency self-noise of the system, you can see that data in my follow-up post here:
    I hope that this helps!
    Chip
  • Chip,
    Your blog posts helped a lot, thanks. Very interesting.
  • Keep in mind that the EEG is a very, very, very tiny signal that exists in the presence of many other signals that are HUGE by comparison. To see these tiny signals in the presence of all the other crap it is necessary to preserve the dynamic range of the system (24 bits) to keep the signal processors from saturating. Just because TI has provide a beautiful signal processor doesn't mean it is any easier. There is a lot going on inside that little part. None of it trivial.
    I added data from our V3 input referred noise tests to the CMRR data page here
    I did two tests. One with the inputs connected internally to GND, and the second with inputs shored externally.
    Cheers,
    Joel
  • Hello,
    EEG signals are so weak that it have amplitude in microvolts . So how openbci module can detect this signals as there are no additional amplifiers in schematic.
    Hi Akash,
    The OpenBCI is built around the ADS1299 IC, which does all the amplification and noise cancellation inside.
    @Akash , hi.
    I merged your thread with an earlier one that has some links and discussion you may be interested in reading.
  • @wjcroft Hi,Thanks for adding my post in this discussion , i read datasheet of ads1299 and now i can say it does not require any external amplifiers for EEG signals . But dont you think there is a need of low pass filter ! for frequencies above 100 Hz .
    Thanks for support.
    See this thread for background on the RC lowpass filters that are on each channel before it reaches the ADS1299.
    http://openbci.com/forum/index.php?p=/discussion/154/front-end-filtering-esd-cmrr-rfi
  • Hi
    I'm designing a prosthetic hand and i am working on signal conditioning part, can anyone please help me in finding the signal filtering and amplification circuits in openBCI
    @sharmilakathirvel , hi.
    I merged your question into this existing thread. See some of the preceding posts.
  • @wjcroft ,
    thank you very much. i understood that all necessary signal conditioning is done by ADS1299. by any chance you know how to do this conditioning without using ADS1299
  • If you would like to create your own signal conditioning, you should look at other projects that use discrete components, rather than OpenBCI which uses the built-in capabilities of a monolithic chip like the ADS1299.
    A good example where you can see the analog signal conditioning elements would be OpenEEG.  Their electronics design is available on their website.  It is shown as having two parts: the amplifier board and the digital board.  It is the amplifier board that you can study to see what elements they used to amplify and filter EEG signals.
    Good Luck!
    Chip
  • @chip
    thank you. it was really helpful
  • XLFXLF India
    edited November 2017
    Hi
    PGA is given as 1,2...24...what's the real value behind this??
    @XLF, hi. Did you read the previous posts in this thread, the gain is programmable, PER channel.
    Also see the Cyton tutorial, where an example is shown of simultaneous EEG and ECG, which operate respectively on microvolt and millivolt level signals.
