Sample rate
when I read " up to 16kHz sampling rate " I thought it is exactly what I need to record the (250Hz) "ripples" from the EEG of my mice...
I thus bought the 32 bits board that I tested yesterday...
But which disappointment to notice that it is not planned in the user interface to choose the sample rate, because it seems impossible to go beyond 115kbauds by radio.
Before I (try to) dive into the code I would like to know if anybody knows what would be the maximum flow rate by writing on the card SD?
Yannick.
Yannick.
Your answer is encouraging I am going to try to dig the question, this device is so nice..., 20 years ago I dreamed to have something like that....
It is a good idea to maintain the display of the data after under sampling when the raw data rate is higher than 250...
Curious, if you are searching for 250Hz signal in your mice, wouldn't 500SPS or 1KSPS suffice?
These
"ripples" are short (100ms) bursts the frequency of which
varies between 100-250Hz, that is why it would be good to have 10
samples by period to reach a correct precision on their frequency and
amplitude,... , 2kHz would be perfect...
In the worst case we can already make a good work by recording the classic EEG...
thanks,
Yannick.
Images -Ripples :
