Decoupling and bipolar power supply
I have some questions regarding the hardware design:
Why do you use bipolar instead of unipolar power supply? Wouldn't that be much easier? What is the advantage?
Why do you have decoupling between AVDD and AVSS and why is decoupling between AVDD and AGND done twice?
Both is not told in the ADS1299's datasheet.
Thanks in advance for any answers!
I'm working on a 64 Channel Amplifier, based on a ADS1298 and I've got exactly the same two questions. I've got the TI Development Kit and can't see any signal differences between uni- and biopolar supply.
Thanks
Is it better to place the decoupling caps as near as possible to the chip corresponding pins? This is also applicable to the VCAP1-4 pins of the ADS1299?
