neuromore Studio, new free visual programming language VPL for OpenBCI
I exchanged some emails with these folks last November, but just saw today that they have released their version 0.9 with OpenBCI support. I'm unsure yet what their business model is, but they are giving away their Studio package at the moment. Perhaps they will have some sort of cloud subscriptions, Freemium setup, or will license for developers to incorporate their engine, etc. I think one of their goals was tight coupling with external virtual reality / gaming apps. Their team roster looks impressive.
Runs on both Windows and Mac, but only has support for OpenBCI on the Windows version currently. Mac support will come in the next release, probably within a month.
http://www.neuromore.com/blog
A whole slew of demos on that same Youtube channel, cool features.
And... at the same time I'd want to mention Jarek's BioEra software, which has been around for a huge number of years and is the basis for numerous commercial neurofeedback packages; such as LENS, Cygnet, ... As far as VPL element blocks with exceptional functionality, versatility, BioEra has quite a lead in this field of neurofeedback VPL.
http://openbci.com/community/neuromore-a-rising-software-acquisition-tool/
Rodrigo, were you running neuromore on native Windows, or under VirtualBox on Mac?
I'm running Bootcamp Win 7 on my Macbook Pro 2015. (Where it runs very smoothly)
Neuromore devs told me they think the problem stems from VRAM reassignment to different contexts when layouts and widgets are loaded. Apparently, some graphic software doesn't behave well with this reassignment. My old Lenovo Y570 with GT 555M also has the same bug.
Neuromore knows about the issue and will keep working on a fix, is my understanding. They have been pretty quick about everything else I've told them so I wouldn't be surprised if this is quickly fixed.
OpenBCI support for OS X should also be coming soon. (Next 2-3 weeks)
Bests,
Rodrigo
Isn't it possible that there is SOME Mac virtual machine combo that will run ok on Mac? For example, Rodrigo tried Win 7 with VirtualBox. And had issues with VRAM. But as you say, perhaps Win 8.1 with VirtualBox would have been a better choice. Or Win 8.1 with another VM such as Parallels, VMware, Xen, QEMU, etc.
Parallels apparently supports user adjustable VRAM settings, this review noticed much better
performance when the VRAM was set to 1 GB, vs. the default 256 MB. The default is even lower in VirtualBox, 128 MB; and takes some tricks to max it out to 256 MB. That's as far as VBox can go.
http://blog.parallels.com/blog/2015/03/31/virtual-machine-performance-myths-debunked/
http://www.neuromore.com/blog/2015/8/25/the-next-generation-of-neuroscience-software-neuromore-studio-v10
Thanks Benjamin, @nomnom (Manu) and your team(!)
http://www.neuromore.com/blog/2015/11/6/neuromore-studio-v11-released
Bluetooth LE heart rate sensors support for OSX
We now support devices like the Polar H7 on OSX, so you can use user heartrate in your calculations and also perform HRV analysis on RR intervals.
New cloud input and output parameter nodes
Our classifiers can now store single values in the backend and load them again at a later time, so now becomes possible to create things like session counters, remember baselines for following sessions or a parameter that is shared between classifiers.
New CSV file writer and reader nodes
Load and save multi-channel data streams in CSV format to your computer, directly from within the classifier.
New frequency bin selector node
A new node that allows you to access the individual bins of a frequency spectrum or convert the spectrum into a multi-channel.
Improved drift correction
A more flexible drift correction with more settings.
Basic heart rate variability node
The new HRV Analysis can calculate metrics like RMSSD or pRR50 for bluetooth heartrate sensors like the Polar H7.
Added Muse Blink and Jaw Clench sensors
Detect eye blinks and jaw clench events with the muse.
Added quantile methods to statistics node
Statistics now support median, quantile and percentile statistic methods.
Display node errors in classifier editor
Show the node error directly in the classifier instead of just in the tooltip.
Settings to enable/disable device detection
Activate/deactivate individual devices drivers in case you don't need them or they interfere.
Added Drift correction and more OSC network settings
We added more parameters to the Studio settings so you can fine tune the drift correction and OSC behavior.
Redesigned neuromore Cloud
A heap of invisible changes were made to our backend to make it even more awesome and ready for the future.
You could probably rig up your own velcro or elastic band 'headset', then route to a lowcost EEG amp such as OpenBCI, OpenEEG, Pocket-Neurobics, etc. neuromore has support for OpenBCI at the moment.
Versus has sensors at C3 Cz C4 Fz Pz; so that might be an option for you. neuromore supports one version of that (research Versus?), not sure about the consumer Versus.
Emotiv EPOC: AF3, F7, F3, FC5, T7, P7, O1, O2, P8, T8, FC6, F4, F8, AF4
Emotiv Insight: AF3, AF4, T7, T8, Pz
http://www.neuromore.com/2016/02/16/beta-testing-neuromore-app/
And a previous blog post with video,
http://www.neuromore.com/2016/01/22/user-testing-neuromore-app/
Also found this December forum post from Benjamin at Neuromore. He states that some time in 2016, there will be two versions of neuromore Studio. The current Community edition which is free. And a Professional edition which has more features.
Unfortunately there is no way to do this within the Community Edition. We already implemented audio triggering based on classifier values as part of our behavior definition system. The feature will be part of the Professional Edition of neuromore Studio and is going to be released next year. [Benjamin]
