dongle issue, device manager shows alert - Win7 x64
Hi everyone
I'm having some (trivial) troubles finding the COM on the GUI. I'm quite sure it's a trivial issue, but right now I'm just stuck.
Let's start from the beginning: I'm using Win7 64-bit, I've followed the Getting started guide, i download the FTDI drivers from here, than I've followed this FTDI installation guide and it still doesn't recognize the device.
What I've done:
- I've plugged the dongle in the USB, the blue led is steady and the switch is closer to the pc.
- the auto-installation has tried to find the drivers but at the end it has failed to install so on the device manager I can find a device (USB Serial Port) with an alert;
- I downloaded the drivers, extracted them and launched dpinst-amd64.exe and it install Bus/D2XX and VCP drivers.
Now everything seems to be ok, but on the device manager the alert has not disappeared and, at the end, the GUI can't still recognize the device.
I've also tried to turn on the board AFTER I had pluged in the dongle, but nothing has changed.
Because I'm using Windows I also restarted the pc, but nothing has changed.
So I opened the forum and started searching.
Here the best result I've been able to find:
nickj: I ended up finding the board under com 3 in the GUI. I think it wasn't showing up before but then I found it. If that doesn't work try to describe exactly where you're stuck.
Can I do anything else in order to let the pc recognize the dongle?
Thanks in advance for the support and sorry for the naive topic (I hope it can be usefull to many people, that's why the long title)
I've not used any usb hub. I installed it manually running dpinst-amd64.exe found in the zip from FTDI. At the end of the installation the wizard says the installation has been completed correctly. I'll try. Ok. Unfortunately my OS is setted in italian so any screenshot would be almost pointless.
Properties/General/Device status:
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
It's the first time I heard of them and I won't lead this path without trying someting less drastic.
It looks like I have to disable signature enforcement, but the idea doesn't make me enthusiast (there must be a reason if it's there).
I wonder why and how FTDI has such unsuitable drivers with an invalid signature for Win7x64.
I'll update you if anything changes using Linux.
I may not answer for some days.
So long, thanks.
4. reboot
i found four files (with the whole directory):
Right now I just don't know what attempt has been crucial. I can try to turn off the Test mode to verify if it works anyway, in that case the root certificate update has done the job.
