ads1299 using ac lead off. how to check the lead off status?
gazamgazam south korea
edited July 2015 in Other Platforms
Hi. I am working on 24ch eeg device with ads1299 chip.
And I need to check the impedance of leads.
my ads1299 setting is..
24 channels of lead connected to [-] input and all [+] input is connected to one reference
so I set the ads1299 LOFF register to 0x03(ac Fdr/4). In my case, it is 125Hz
and LOFF_SENSP to 0(zero) and LOFF_SENSN to 0xFF
I got datas in my pc and analyzed it with FFT
I expected that there shold be a power(?) in range of 125Hz only when lead is connected to reference
but I also got a amplitudes in  other channels which are not connected. other channels have 125Hz signal.
I thought that chennels affected by all [+] input tied one reference.
Is it working right? so I thought that I dont need FFT to check the lead off status. is it right?
I just calculate the impedance with only Vrms and current.
have two questions.
one. Do I need to FFT to know lead off status?
two. when measure the real eeg data, do I turn off the ac lead off function?
thanks.
have a good day.
