ADS1299 with Arduino DUE Sampling problem
I have EEG Front-End Performance Demonstration Kit and got clear idea bout the operation of the chip.
Then I decided to use ADS1299EEG-FE Daughter Card separately with Arduino DUE.
Then I made all the necessary connections(SPI , Reset, Start, DRDY) between Daughter Card and Arduino. The required power (3.3V and 5V , GND) are supplied from Arduino board.
When I run the program it shows the default register values correctly as follows. That implies the chip powered up correctly
Then I Modified CONFIG3, CONFIG1, CH1SET   registers to apply TEST signal to CH1 and take 250 samples.
But the problem is I don’t observe the correct Square wave form from the channel.
The waveform is in this graphs but there are un expected peak values (errors) ..
Sometimes the graph shows almost correct with small level of error values as follows
Please help me to correct this. I think I’m almost done but stuck at this point. :(
