Buying Dry / Active Electrodes
24
  • I've learned that Cognionics is now selling their dry flex sensors for
    $40 each, or $15/sensor in quantities greater than 100:
    http://cognionics.com/index.php/products/sensors/flex
    Cognionics sensors were successfully used with OpenBCI in a recent exploratorium exhibit:
    http://openbci.com/forum/index.php?p=/discussion/319/cognitive-technologies-maker-expo-at-sf-exploratorium
  • Actually, here are price quotes I had some months ago:
      Quantity    1-5:      $40.00 each
      Q             6-19:      $30.00
      Q           20-39:      $25.00
      Q           40-99:      $20.00
    At 15$ per sensor, it's starting to be *really* interesting. Anybody to team-up for collective purchase order?
    I received my dritz for the Ag/AgCl electrodes  (seems to fit!), but I'm ready to spend few more bucks for more reliable electrodes and... less soldering :D
    I wonder how many "sessions" each sensor is good for, before the chloride portion of the Ag-AgCl starts to wear off. There is a silver plate below that, but the chloride is what give the best signal quality. With silver plate alone you would still get a signal, but then it's technically NOT a Ag-AgCl electrode.
    With the flat Ag-AgCl buttons I use in the velcro saline headset -- buttons last about 40 sessions before the coating wears off in patches. Then the buttons must be replaced; only 50 cents per button.
    These spring loaded combs put a lot more friction and pressure on the tiny area of the tips. So I would expect they would get less than even half of that, 20 sessions per replacement? Can someone ask Cognionics?
    There are ways to re-chloride your silver plated electrodes, perhaps that is another avenue,
    https://www.google.com/search?q=making+silver+chloride+electrodes
  • Thanks for the info William, I wasn't aware of the possibility of this type of degradation.
    I've gotten prompt responses from Cognionics when using their online contact form:
    http://cognionics.com/index.php/contact
    You might try asking your questions there and see what they say.
  • Has anyone tried making their own silver electrodes?  Silver is a bitch to plate, but luckily it's cheap!
    Chloriding the silver is easy enough.
    Below is the reply I got back from Cognionics. I guess they have really heavy duty plating on their tips; or these buttons I'm using have light plating. :-) Would certainly be worth a "road test" however before pegging the number of sessions as "infinite"...  As I mentioned above the chloride layer could disappear and still have conductivity through the silver plate. But that would be a silver electrode and not Ag-AgCl.
    Some of the Cognionics headsets also use Active Electrode circuits at each comb sensor. In that case silver or gold or Ag-AgCl would all perform about the same. With passive sensors, electrode metal is more an issue.
    Hi William.  We have not seen tip wear to be a problem as long as the device is only used on heads.
    Michael Elconin
    Cognionics, Inc.
    [email protected]
    (619) 302-8686
    I used passive dry electrodes from Florida Research Instruments while at SXSW
    They worked exceptionally well with no gel (!)
    The cables plug into our touch-proof connectors, which come standard in the OpenBCI kit
    The FRI electrodes come in two types: one to get through the hair, and one for direct skin contact.
  • Those electrodes look pretty nice.  The electrodes are cheap (15 for $10), but the lead wires are expensive (~$8 each).
    Anybody have a source for the clips?  Maybe FRI would do a DIY lead kit?
  • You can use an alligator clip as an inexpensive
    alternative.   The leads we sell are not the standard snap
    but allow you to inject gel into the top of the electrode.  The top of the electrode has a hole in it so
    it is also larger than the snap electrode. We sell a package of 25 electrodes
    and 3 leads for 34.95  and 25 electrodes
    and 5 leads for $48.95.  They are on our
    web site www.FRI-FL.com
    Karl Zurn
    edited March 2015
    Jake, also read the previous page on this thread. Shows the velcro system from FRI, which would make it easier to hold the sensors in place. And some posts from @ecube showing his snap adapter. In other words, you can make your own leads that attach directly to the snap.
    To Karl's great credit, he found a way to bring the price down on these, enormously from what Biopac was selling them for. See that first page. And if you look around on various EEG supply sites, $8 for a touchproof EEG electrode is about as low as they are priced. Of course you can do without the touchproof if you want.
    ECG snap connector 5 lead touchproof sets are available for around $30.
    edited March 2015
    Just ran across a recent Kickstarter project using spring loaded active gold contacts. Unsure how comfortable these are, they look large and pointy. They get the spring loaded contacts/pins from this company. Using the INA116 instrumentation amp. (Our ADS1299 delta-sigma design makes IA's unnecessary.) So overall an admirable project, but looks somewhat unwieldy.
  • Dear all,
    I am a new members. I want to buy dry eeg electrode and lead. I find eeg electrode EL120, and LEAD120-W (https://www.biopac.com/silver-silver-chloride-post-electrode) and
    Disposable / Reusable Dry EEG Electrode [TDE-200], TDE-207XX Lead (http://fri-fl-shop.com/product/tde-200/) that are similar? Please help me.
    The $40 leads from Biopac are an anomaly. They are the same product that FRI sells for much less. Get them from FRI in whatever quantity you want.
  • Our Web Site is www.fri-fl.com   What you need is fri-2140-1A  5 wires and Dry and Wet electrodes for 4 EEG leads and common.
    Karl Zurn, Florida Research Instruments Inc.
  • edited April 2015
    Dear KZurn,
    I want to buy the package below. I can not find on web site www.fri-fl.com and I don't know to pay. Please help me
    "If some OpenBCI  people want to try out EEG Dry Electrodes I
    can offer a special price for Package of
    25 Disposable / Reusable Dry Electrodes & 3 Lead Wires (FRI-2140-1) $29.95
    and this including shipping.  It is a
    savings of about $10.  They can be seen
    on our web site www.fri-fl.com  If anyone is interested send via PayPal $29.95
    to [email protected]
    with a note that it is for the OpenBCI Dry Electrode Offer."
    Thanks.
  • Dear all,
    I come from Vietnam. I bought some items from fri-fl-shop some items: Disposable / Reusable Dry Electrodes and lead wires on 14.4.2015.
    Until now, I don't recieve any items. And I check USPS package tracking, they have been US. How long  can I get them? Please help me.
    Thanks.
    @trungnv , you should email directly to the address on previous post,
    [email protected]
    Ask them how it was sent and the tracking number. FRI handles the order directly. Other contact info here,
    http://www.floridaresearchinstruments.com/contact/
    Two weeks for U.S. to Vietnam (not express) package, seems not unreasonable. I believe the $30 price quoted was probably for U.S. orders, and not including extra postage for foreign. If you did not send them extra postage, it might have gone via surface(!)
  • The time for Europe via USPS First Class is usually
    about 1 week.  Some South American
    countries can take a month.  This is our
    first order to Veitnam.  The main delay
    is usually in the customs of the person’s country. We are looking into DHL for
    shipping.  I will post the information on
    our site.
    Karl Zurn, Florida Research Instruments Inc., www.fri-fl.com, [email protected]
  • Here is an easier way to obtain the $15 discount on the headband
    set
    The webshop link for the headband set is at
    http://fri-fl-shop.com/product/dry-eeg-drywet-electrodes-eeg-headband-and-5-cables/
    Add it to your shopping cart, and when you check out, enter the
    code
    bcistart
    into the coupon box and click "apply coupon". It's
    directly below the cart's item list. The total will refresh with the discounted
    price. Then you can finish checking out with paypal.
    Karl Zurn, www.fri-fl.com
  • This Coupon will expire July 1, 2015
  • Hi,
    Kind of a tangential question, but is there anyway to order an extra set of the touchproof to female header pin connectors that comes with the OpenBCI kit?
    I'm planning on getting the headband + dry/wet electrode kit from FRI mentioned above,but will need adapters to connect to my board. I see that Chip has a tutorial on eeghacker but I'm hoping to avoid piecing it together if possible.
    @Gromit , hi.
    I'm guessing Joel @biomurph will comment about the touchproof adapter cables. Since these come with all OpenBCI kits, I'm surprised you do not have one. They likely have extra stock of these 8 cable sets.
    I also thought of one other way you could make your own header pin adaptors, if you are willing to cut your touchproofs off (say 6 inches from the end). Admittedly a 'kludge', :-)  However, these M/F jumpers,
    https://www.adafruit.com/products/826
    If cut in half, would allow you to splice the female on the electrode cable. And the male onto the touchproof stub. That way you could use your FRI cables either with .1" header connections or with touchproof equipment if that happens sometime down the road in your future.
  • Thanks for the reply @wjcroft. I actually don't have an OpenBCI kit so that's why I was looking for the touchproof adapters separately...I hope to order a kit at some point though.
    I'm interested in doing some EEG recordings + computations, and at the moment I've just been playing around with a couple microcontrollers that I have. I'll be making a board with the ADS1299 as the front-end anyways so a simple option could be to just have the male touchproof jacks right on the PCB itself. Thanks for the tips!
  • edited June 2015
    The male touch-proof jacks are a bit expensive and they're pretty large...especially if you're putting 10 on there (8 EEG chan + 1 for the reference + 1 for the bias).  So, before you jump in with your own board, do be aware of the increase in size that'll be necessary.
    Plastics1 keeps changing their website, but the current webpage for these components is:
    I looks like P/N 41828 are the male PCB-mount 1.5 mm touchproof jacks.  They're $20.10 for a package of 10, which is cheaper than I remember.  Cool.  They're still pretty big, though.
    Chip
  • As far as I know there is not another connector that
    is as safe when working with human subjects than the 1.5 mm touch proof plug,  Even the .1 female connector that OpenBCI
    uses could be connected to a pin that has voltage on it.
    Karl Zurn
  • Hey,
    Have anyone tried any dry-electrodes sensors which can be used like a wearable headset.
    For Ex. Emotiv Epoc+
    The poblem with this module is its electrode positions does not involve C3, C4,Cz positions which are crucial for motor imagery experiments
    From the forum posts, I came to know about this,
    Did anyone try it? What about its reviews and performnance?
    Mohit
    edited June 2015
    Mohit, hi.
    > Has anyone tried any dry-electrodes sensors which can be used like a wearable headset?
    (1) Conor has these same dry combs mounted in his prototypes of the printable headset; spring loaded.
    (2) The velcro band/strap concept becomes like a 'headset' if you have several cross straps installed. The whole unit could be lifted off and replaced on your head later without having to reposition each strap. Assuming you are using it on the same person each time.
    (3) The g.tec g.GAMMAcap (elastic cap with holes at 10-20 locations) -- would work pretty well as a dry sensor 'headset' with the advantage that the Medium cap fits most people. ("one size fits [almost] all").
    (4) The BraiNet elastic hole guide (mentioned earlier on this thread), is another elastic 'cap' like solution.
    The Cognionics looks fun, but I'll bet is considerably more expensive.
  • I asked Cognionics about the Quick-dry 20 headset a few months ago. A fully-populated unit with 19 channels plus reference and ground costs $14,600. A 3-channel unit costs $2800.
  • Hi,
    Thanks William and Kartik for your comments on products.
    Cognionics is way expensive.
    I am now thinking about purchasing, g.tec G.GammaCap with G.Sahara electrodes. I want to connect these electrodes to openBCI module.
    Can you help me what exactly i have to buy to make this work and estimated cost range.
    I looked at the product description, there is no price quote present. Moreover, the G.Sahara electrodes does not come with a connector which can be connected to touchproof connector.
    Mohit
    edited May 2017
    The g.tec dry actives (g.SAHARA) are less than Cognionics, but still expensive,
    http://openbci.com/forum/index.php?p=/search&Search=saharabox
    The g.SAHARAbox converts the active electrodes into conventional 'passive' touchproof electrode signals. I never got the price broken out to see what the g.SAHARAbox itself cost.
    I'd suggest (as before) just using the reasonable cost g.GAMMAcap with the FRI dry passive electrodes. With the OpenBCI clipped to the rear of the cap or say back of shirt, leads will be quite short. In general, active electrodes drive the price way up (at least with research type equipment).
