So you are saying the switch is stuck in one position? Can you just use a needle to move it to the PC position and leave it there? Then plug / unplug your power to act as an on off switch. Or you could get one of the JST-PH power extension cables from Adafruit and plug / unplug at a halfway point. Or install a switch on that cable, etc.
Your photo did not come through. Try linking to an image on Google Drive for example. Note you can not use a local C: drive image to post on the forum. It has to be a file server URL.
https://www.adafruit.com/products/1131
[extension cable]
