which input pins when using multiple EEG channels?
I'm planning to run some tests where 2 electrodes are connected to the front of the head and two other are connected to the back. So, total of 4 electrodes.
I would like to get some advice on what is the best way to connect these electrodes to OpenBCI input pins. Would it make sense to connect the frontal electrodes to pin 1(positive and negative) and to pin 2(negative and positive) connect the two back electrodes?
What about biasing and reference? I have noticed in the example in "getting started with OpenBCI" that you were using both SRB2 and biasing - what is the advantage of using both?
Mike
Please it will be helpful if u explain step by step...
Setting up 8 channels is just the obvious extension of the process in the tutorial docs. Your 8 actives go on the 'N' pins. Reference on SRB2.
Why the actives channels go on 'N' pins? I would connect actives to 'P' pins and reference to 'N' pins.
