Open-source light/sound neural entrainment device — looking for EEG feedback (no clinical claims)
Hi everyone,
I'm Aaron, an independent maker/builder — sole developer of NeuralInducer.org, an open-source, non-commercial project exploring neural entrainment through light, sound, and vibration (Arduino-based devices).
I want to be honest upfront: I don't have EEG data yet. What I have is consistent subjective feedback from myself and several family members who use the devices regularly — reports of relaxation, easier sleep onset, and a "settling" feeling during the alpha protocol. That's it. No clinical claims, no "proof" — just a device that seems to do something, and a builder who wants to know if it actually induces measurable brain activity.
If anyone here has a Muse, OpenBCI, or similar setup and is curious to test it and look at the EEG, I'd love the feedback — good or bad. I can share build files, firmware, and full protocol details. Everything is open-source (CC BY-NC).
If you want to dig deeper, the full project — including the scientific background and research papers behind each protocol — is documented at neuralinducer.org.
If you're in the US and interested in testing the physical device itself rather than replicating it, I currently have two NeuroSync ALPHA units built (firmware v6.x — includes vibration/beep, Modo D) ready to send out — happy to work out the details with whoever's interested.
I'd genuinely appreciate any help with this project — whether it's testing, feedback, or just pointing out where I might be wrong.
Happy to answer questions here — my written English is decent, please bear with me if I take a bit to reply.
Aaron, thanks for your post and offer.
One other place you should consider posting is the Slack run by NeuroTechX, there are thousands of researchers, students, makers that monitor the posts there. Pull down the Community tab on this website, then select Slack:
https://neurotechx.com/
Thanks so much, wjcroft — I really appreciate the pointer. I'll check out the NeuroTechX Slack as well. Really glad to be part of this community.
Aaron, there’s a first recording you can make without a volunteer. Have the EEG system record from a test load while the device runs nearby, with the cables arranged as they would be for a session. Compare device-on and device-off periods. A peak at the drive frequency in that recording would give you an artefact to track down before interpreting a scalp spectrum. A clean bench recording would only clear that particular setup.
I’d also record the actual light output with a photodiode. Then anyone looking at an eventual EEG trace has a measured stimulus time course to compare it with. A response locked to the flashes during stimulation and a change in resting activity after the flashes stop are two different outcomes. Which would you most like your first dataset to answer?
Hi, thank you for your reply and for such concrete advice.
I’ll be upfront about my situation: I don’t have an EEG board yet, as it’s too big an investment for me right now. My project is a freely accessible research project (NeuralInducer), and I work with a light-stimulation device that I built myself.
Because of that, I can’t do the bench test yet. What I can do right now is what you suggest with the photodiode: record the actual light the device emits, to check the exact frequency, the shape of the flicker, and whether there is hidden noise, for example from the LED PWM. I’ll start there and share the data.
To answer your question: my first dataset should answer the most basic question, which is whether my equipment contaminates the signal or not. After that, with a volunteer, I’d like to see whether there is a response locked to the flashes during stimulation. I’m leaving the after-effect for later, once the protocol is clean, and I don’t want to claim anything before I have data.
One question: do you know of an affordable way to get access to an EEG for a bench test, or someone on the forum who might be willing to collaborate? All the documentation, firmware and schematics for the device are public at https://neuralinducer.org/descargas.html (CC BY-NC 4.0 license), in case you’d like to take a look.
Thanks again,
Aaron
Aaron, you could ask a board owner to run the test on their own bench. That saves you buying a board and saves them lending one. When you share the photodiode trace here, include a short raw file, the sampling rate and a photo of how the lamp and cables were arranged. Someone can then see exactly what they’d need to reproduce.
If the lamp needs to stay with you, a nearby university EEG methods lab or biomedical engineering teaching lab would be my first enquiry. Give your city or region if you’re comfortable doing so, and ask for a short bench session with a test load, no participant. A lab can give you a much clearer yes or no to that than to a request to collaborate on the whole project. I don’t have a confirmed loan contact to pass on.
