How do I know that my OpenBCI rig is working based on readings on OpenBCI GUI?
Hello everyone,
I'm based in Singapore (50Hz mains), and I borrowed an old OpenBCI unit (Cyton) from a professional acquaintance, and:
  • 3D printed my own Mark III headset with the electrode holders and whatnot
  • used normal regular jumper cables
  • used comfort combs from the store (link)
  • screwed on my own nuts and screws
Here's what I see on the OpenBCI GUI when I used my own 8-channel montage - one is with 50+60Hz filter and the other is without:
How do I know if my headset is working properly? I am very perplexed by the straight lines after filtering. Thank you in advance everyone!
  • mhoughmhough San Francisco, CA, USA
    Hi Jackie,
    When you say straight lines are you talking about your supression of 70Hz+ in the bottom image? What do you see with a 40Hz low pass filter.
    You can record some resting data, look for eyes open-eyes closed differences or even better record some task data (using EEG-ExPy) and see if you can collect some ERPs to test out your hardware.
    Hope that helps.
    Cheers,
    -Morgan
    Morgan, thanks.
    Jackie, hi. I see you have the Time Series widget graph 'Vertical Scale', set to 'Auto' which tends to zoom in on a very low range (below 10 microvolts) of EEG. Typical EEG range is more like 80 - 100 uV full scale. So recommend just setting Vert Scale to that range.
    As Morgan suggests, the classic easy test for parietal or occiput scalp locations, is to watch for increased alpha when you close your eyes. This will be visible in the Time Series, FFT, and Band Power widgets. You definitely want to continue using the notch filter at 50 Hz. But as Morgan suggests, you can even employ a bandpass filter from say .5 to 40 Hz to further cut down on the mains noise.
    https://docs.openbci.com/GettingStarted/Biosensing-Setups/EEGSetup/ [see Alpha section]
    https://docs.openbci.com/Software/OpenBCISoftware/GUIWidgets/#filters [filter adjustment]
  • Jackie, one way to make the two screenshots easier to compare is to record a short segment once and replay that same file twice. Use the same channel, time window and fixed vertical scale for both views, changing only the notch setting. That way, even the blinks and electrode movements are identical. In the spectrum, does the main change sit around 50 Hz, or does power fall across a much wider range? A trace can look flat on a scale set by a large mains peak even when a smaller signal is still there. A pair of plots from the same recording, with the axis units visible, would help answer your question about the straight lines.
