Open-source PRAYCG pipeline: OpenBCI/LSL media protocol, timing QC, and exploratory EEG/autonomic
hbanks87hbanks87 kansas city
edited August 20 in General Discussion
Good evening,
I am preparing to release an open-source experimental pipeline built around OpenBCI, Lab Streaming Layer, media-based cognitive tasks, and post-processing analysis. I would like to share the GitHub/OSF materials here for technical critique from the OpenBCI community.
This project started out as an intense curiosity and has been a tremendous amount of fun. This is not a professional project. I did this for fun. I have no real idea as to whether it is valuable to anyone. The project is called PRAYCG. It is an exploratory psychophysiology protocol and software stack for testing whether naturalistic narrative stimuli produce measurable EEG/autonomic state trajectories beyond low-level sensory entrainment and beyond analytic task demand.
This is not a clinical tool, not a diagnostic system, and not a claim that OpenBCI can prove consciousness, memory biology, or any metaphysical theory. It is best understood as an open-source methods workbench for stimulus preparation, acquisition logistics, timing/QC, and exploratory analysis.
What the protocol does
The core design is a three-arm naturalistic viewing protocol:
Phase-scrambled sensory control
The source video is scrambled so recognizable story/faces/narrative meaning are damaged while low-level audiovisual structure is partially preserved. This is meant to ask: “Is the response just light, sound, motion, cuts, rhythm, cue timing, or audiovisual energy?”
Target narrative
The intact narrative is watched naturally. This asks: “What happens when the story is allowed to land?”
Contextual Override
The same intact narrative is watched again, but with an analytic task, usually an upper-right number-cue running-sum task. Target and Override use the same cue-embedded video; only the instructions differ. This asks: “What changes when the participant is measuring/extracting rather than receiving?”
Current hardware stack
My current setup uses:
OpenBCI Cyton + Daisy
OpenBCI gelfree/gelless cap workflow
BrainFlow/LSL EEG stream
LabRecorder XDF recording
ALS-PT19 or similar light sensor for physical screen timing
Polar H10 R-R intervals
Vernier respiration belt
optional Faraday/shielded enclosure setup(see the box section on github)
PRAYCG2.0 protocol runner with structured event logs and self-report/confound reports
What the software release includes
The repository contains or will contain:
MediaPrep + StimulusFingerprint
prepares Target, Override, and phase-scrambled Control videos
embeds cue schedules
generates stimulus-side QC and exogenous regressors
supports predeclared anchor files for event-locked analysis
PRAYCG2.0 Protocol Runner
loads Control, Target, Override, cue schedule, and anchor file
logs structured events
includes pre-run display/audio calibration
includes branch-level self-report and confound reports
includes final reflection baseline
supports override task reporting
BrainFlow / ALS / LSL tools
OpenBCI streaming helpers
ALS/PT19 timing-sensor support
LabRecorder workflow documentation
stream checklist and timing-QC workflow
Master Comprehensive Analysis Suite
time-resolved feature extraction
artifact scoring
stimulus-regressor residualization
MRED/A-MRED endpoint-compression modules
MRED-Peak vs MRED-Resolution
DGA / Decoder Gate Availability
NUPI / Narrative Update Polarity Index
visualization tools
offline plain-English report generator
Documentation
full end-to-end SOP from media procurement to analysis
hardware- how to build a faraday cage for eeg studies
formula/module explanation report
Main analysis idea
The current primary analysis direction is called MRED: Meaning Recognition / Encoding Dissociation.
In plain language, MRED asks whether the system can distinguish:
immediate recognition of meaningful material, versus
delayed integration, after-state, or regulatory carryover.
The compressed endpoint layer currently separates:
MRED-Peak: acute anchor-locked recognition + delayed integration
MRED-Resolution: slower reflective/regulatory recovery after the stimulus
A-MRED: anchor-locked MRED candidate that must pass condition, artifact, and QC gates
I am not treating gamma as a “meaning biomarker.” Lower-gamma/high-frequency features are treated as artifact-sensitive candidate work-signal proxies. The pipeline tries to penalize or flag muscle activity, eye/forehead artifact, cue burden, sensory drive, respiration, confounds, and exogenous stimulus timing.
Why I am posting here
I am looking for critique from people who know OpenBCI, EEG acquisition, artifact handling, and LSL better than I do.
The areas where I most want feedback are:
OpenBCI Cyton + Daisy acquisition reliability
gelfree/gelless cap best practices
BrainFlow configuration
LSL stream naming and synchronization
LabRecorder setup and XDF recording workflow
ALS/PT19 photodiode/light-sensor timing validation
whether my start-pulse design should be longer or barcode-like
artifact control for gamma-band claims
EOG/EMG channel additions
jaw/forehead/eye artifact separation
respiration and HRV integration
whether the analysis suite is overbuilt and how it should be simplified
how to make the public GitHub repository easier for other OpenBCI users to run
Current limitations
The project is exploratory and self-run so far. Several pilot runs revealed exactly the kinds of issues that need better engineering:
timing-pulse detection needing a better physical ALS holder
BrainFlow/OpenBCI effective sample-rate variability
cue visibility/legibility issues in some stimuli
gamma-band artifact vulnerability
the need for EOG/EMG
the need for cleaner locked-anchor and timing workflows
I am not presenting pilot outputs as confirmatory. The point of the current release is to expose the machinery and invite technical critique before treating anything as strong evidence.
Links
GitHub repository:
https://github.com/hbanks87/praycg-open
Here is a list of the fun ideas/theories that I have come up with as a result of running this protocol. The following are not proven claims. They are the current working hypotheses made visible by the protocol,
software, and pilot failures/successes:
  1. Meaning recognition and meaning integration can dissociate. A subject can recognize meaningful geometry without showing clean delayed integration under current proxies.
  2. Peak-like meaning and resolution-like meaning appear to have different physiological shapes. Some events strike sharply; others settle slowly into afterglow.
  3. Analytic extraction does not simply erase meaning. It can reroute, delay, tax, or alter the route by which
    meaning is accessed.
  4. Sensory clarity and emotional impact are separable. Clearer semantic access can occur in one branch while stronger emotional absorption occurs in another.
  5. Meaning requires access conditions. Sensory access, prior state-space, personal relevance, autonomic
    availability, low task burden, and low confound load all matter.
  6. Baseline2 may be one of the most important windows for integration, but it is cumulative and cannot be attributed to Target alone without stronger design.
  7. The phase-scrambled Control remains essential because sensory entrainment and meaning integration are not the same construct.
  8. The suite is increasingly a theory of availability: whether a living system is available to decode, receive, and be changed by meaning.
Again, this is not a claim of proof. It is an open-source exploratory pipeline, and I am sharing it because I want the engineering and analysis assumptions challenged.
Thank you for taking the time to read this and have a wonderful day,
Hoyt
    Hoyt, thanks for posting your open source project.
    I did find this document in your Github which provides a bit more background:
    https://github.com/hbanks87/praycg-open/blob/main/docs/PRAYCG_Working_Theory_PUBLIC_v0_6.pdf
    Can you elaborate on your project title, acronym, PRAYCG, which according to the Github breaks down to: PR-AYC-G. One of your summary statements above says:
    So, some kind of 'story' is told, via various forms of narration (video, audio?), along with certain control stimuli which are expected to produce more predictable responses. If the narration is being received / interpreted correctly, isn't it natural to assume it 'lands' in the consciousness of the subject and is understood? Unless the person is sedated, isn't it normal to assume this reception goes beyond sensory entrainment? Does the story have emotional content, and you expect to measure emotional valence; EEG has been used for this in the past. It also sounds like some of your runs will impose moderate task loads on the subject, I assume to track whether this interferes with the story landing?
    What kind of applications do you foresee with your project?
  • hbanks87hbanks87 kansas city
    edited August 20
    Hey William,
    Thank you so much for taking the time to read my post and go through the github! Sincerely. Thank you for your time. My edited response:
    You are right that, in ordinary language, if an awake person watches a story and understands it, we usually say the story “lands.” I am not trying to prove that people understand stories.
    The narrower question is whether we can separate several things that usually arrive tangled together:
    low-level audiovisual entrainment,
    semantic or emotional reception of the story,
    analytic task load, and
    delayed after-state or carryover.
    That is why PRAYCG uses a three-arm structure.
    The current protocol is approximately:
    Baseline 1
    Eyes-open stillness baseline.
    Phase-scrambled Control
    The same source video is scrambled so recognizable story/faces/narrative content are damaged while some low-level audiovisual structure is preserved. This branch is not assumed to be physiologically dead. It is meant to ask whether a response can be explained by light, sound, motion, cuts, rhythm, cue timing, or audiovisual energy. This is achieved by a fourier transform to both audio/visual files.
    Washout 1 + brief self-report / confound report
    Target Narrative
    The intact narrative is watched naturally. This is the receptive condition.
    Washout 2 + self-report / confound report
    Contextual Override
    The same intact cued video is watched again, but the participant performs an analytic task. In my current version, this is usually a running-sum task using number cues displayed in the upper-right corner. Target and Override use the same cue-embedded video; only the instructions differ.
    Washout 3 + Override task report
    Final reflection baseline
    A second 2-minute baseline after all three branches, intended to capture possible after-state / reflective carryover.
    Final comparative self-report
    The key engineering detail is that Target and Override are intended to be the same rendered stimulus file or bit-identical cue-embedded versions. The participant’s stance changes; the audiovisual input should not. The phase-scrambled Control is generated from the cue-embedded Target so that cue timing and low-level cue energy are represented in the control branch as well.
    So yes, the story has emotional content. But I am trying to avoid treating this as a generic “happy/sad” valence-classification project. EEG has certainly been used for emotion/valence work before, and I am not trying to reinvent that. PRAYCG is more interested in the time course of a cognitive-emotional event: initial recognition, possible integration, task interference, and post-stimulus carryover.
    The internal term I am using for this is MRED, Meaning Recognition / Encoding Dissociation. In plain language, MRED asks whether recognizing a meaningful moment and integrating or carrying it forward afterward are separable. A participant might understand a scene but not show much after-state carryover. Another scene might not produce a sharp peak but may produce a slower reflective afterglow. Another condition might preserve semantic understanding but change the physiological trajectory because the person is doing an analytic task.
    The Contextual Override arm is meant to test that last issue. If the same intact stimulus produces a different EEG/autonomic pattern when the participant is forced into a running-sum task, that supports the idea that task stance matters and that the Target response is not reducible to the video stream alone. It does not prove meaning by itself; it adds one contrast.
    The current data streams I am working with include OpenBCI EEG, LSL markers, optional ALS/PT19 light-sensor timing validation, respiration, Polar H10 R-R intervals, self-report, and confound reports. The analysis suite includes artifact scoring, stimulus fingerprinting, timing checks, lower-gamma/theta features, autonomic summaries, and an offline report generator. I am treating gamma as an artifact-sensitive candidate feature, not as a meaning biomarker.
    As for the acronym, PRAYCG began as an internal codename from a broader theoretical project. For the public OpenBCI release, I am treating PRAYCG mostly as the project label. The empirical content is the three-arm protocol and the open-source pipeline, not the acronym.
    Applications are still speculative. I do not see this as a clinical, diagnostic, or commercial tool right now. The immediate value is more basic and methodological:
    an OpenBCI/LSL naturalistic-stimulus protocol,
    a reproducible media-prep and phase-scrambling workflow,
    a timing/QC workflow using LSL and light-sensor validation,
    a way to compare natural viewing against analytic task stance,
    a testbed for gamma/artifact criticism in naturalistic EEG,
    and an educational/open-source workbench for people learning multimodal EEG acquisition.
    Longer term, if replicated with more participants and better hardware controls, it might be useful for studying media cognition, attention, cognitive load, affective neuroscience, BCI stimulus design, and how narrative material interacts with autonomic regulation. But the current repository should be read as exploratory methods development, not as a finished neuroscience claim. I believe there may be some hypotheses here for temporal smearing as well.
    The main critique I am looking for from this community is practical:
    Is the OpenBCI acquisition/timing strategy sane?
    How should I improve ALS/PT19 timing validation?
    What EOG/EMG additions would most improve artifact control?
    How would you simplify the analysis stack?
    What would make the GitHub repository easier to audit and run?
    Where am I making unsupported assumptions about the hardware?
    So I agree with your framing: stories normally land when people understand them. PRAYCG is trying to ask a more technical question: can we measure differences between sensory entrainment, story reception, analytic extraction, and after-state carryover in a way that survives artifact and timing criticism?
    Hoyt
    Good afternoon everyone,
    I made several updates to the PRAYCG GitHub repository and wanted to share them here for anyone interested in reviewing the workflow or testing the software locally.
    1. Master theory and protocol document
    I added a public-facing master theory/protocol document here:
    https://github.com/hbanks87/praycg-open/blob/main/PRAYCG_Master_Theory_and_Protocol_PUBLIC_v1_0.md
    This document gives the broader structure of the project.
    2. PRAYCG Control Center
    I also uploaded an early work-in-progress PRAYCG Control Center release:
    https://github.com/hbanks87/praycg-open/releases/tag/PRAYCG_CC
    The Control Center is meant to be a single desktop hub for the PRAYCG workflow. The goal is to reduce the number of separate scripts a user has to remember.
    3. Installation and workflow instructions
    I added two beginner-facing documents for the Control Center and PRAYCG workflow:
    Control Center installation guide:
    https://github.com/hbanks87/praycg-open/blob/main/software/PRAYCG_OPS_v1_3/13_PRAYCG Control Center_v0.5/PRAYCG_ControlCenter_v0_5_Installation_Guide.pdf
    Stimulus-to-analysis workflow:
    https://github.com/hbanks87/praycg-open/blob/main/software/PRAYCG_OPS_v1_3/13_PRAYCG Control Center_v0.5/PRAYCG_Stimulus_to_Analysis_Workflow_v1_0.pdf
    These are written for users who are only mildly familiar with Python and Windows software installation. They cover Python 3.11 installation, dependencies, Control Center launch, stimulus selection, MediaPrep, acquisition streams, LabRecorder, PRAYCG2.0, and running analysis afterward.
    4. “The Box” hardware documentation
    I also added documentation for what I have been calling “the box”:
    https://github.com/hbanks87/praycg-open/tree/main/hardware/the_box
    This is my nickname for a DIY Faraday-style enclosure I built for my own EEG experiments. I uploaded a PDF with 30+ pictures and construction notes.
    To be clear: the box is not required to run PRAYCG. It is just my current local acquisition environment. I am sharing it because some people have found it interesting or useful.
    Thank you again for the feedback so far, William.
    Hoyt
    Link to v0.95: https://github.com/hbanks87/praycg-open/releases/tag/PRAYCG_V0.95
    I wanted to share an update on the PRAYCG toolkit. The project has continued to evolve from a collection of separate scripts into a much more organized OpenBCI / BrainFlow / LSL workflow package.
    What changed from the earlier v0.6 releases to v0.95
    v0.7–v0.93: Physical Timing, New Controls, and Better Organization
    • ALS / Photodiode Timing: The runner now supports physical screen-timing checks. A software "start" marker doesn't always equal the exact moment light changes on a display, so the ALS/PT19 sensor gives us a physical validation of the stimulus onset.
    • ShotOrderScramble: Phase scrambling (the original control) is great for preserving low-level sensory structure while destroying the story, but it also destroys faces, bodies, and natural motion. ShotOrderScramble fills that gap by detecting local shots and shuffling their order. It keeps local visual structure recognizable but breaks the narrative sequence.
    • Protocol Library: The package now cleanly separates protocol templates.
    • PRAYCG3 is the standard three-branch protocol (Phase-scrambled Control, Target, Override).
    • PRAYCG4 adds the ShotOrderScramble branch to test if the Target response is stronger than both a low-level scrambled control and a structurally recognizable but narratively disordered control.
    • SMG (Semantic Meaning Gradient) is a new template comparing coherent but low-meaning stimuli to high-meaning targets.
    • Windows Reliability & Organization: Several updates focused on better tracking of which stimulus and run folders are used, dependency repair, and cleaner process shutdowns so third parties can audit run folders without ambiguity.
    v0.94–v0.95: Expanded Confound Controls
    A major goal of the newer analysis suite is to aggressively challenge a result before interpreting it. The new confound modules ask:
    • HOC-R: Could the Target effect be explained by high-order visual features like faces or biological motion?
    • OSA: Could the Override result be explained by where the participant was looking (e.g., staring at number cues in the corner)?
    • OHC & AAM: Could the result be explained by order fatigue, or is the final baseline just relief from finishing a task?
    • RespDualPath: Could a sigh or breath hold explain the EEG/HRV shift?
    • DGA (Decoder Gate Availability): Could the participant actually access the meaning, or was the audio poor, the task too burdensome, or the environment too noisy?
    • CET-R: Could the result be explained by exogenous media properties like luminance, audio envelope, cuts, or cue timing?
    None of these modules magically "fix" the data. They are safeguards that help decide if a result deserves interpretation or should be treated as confounded.
    Continuous Physiology (CAI/SID and CAA)
    The newest versions add more exploratory analysis modules to make interpretation more time-resolved and falsifiable:
    • CAI/SID (Controlled Access-Integration Index / State Integration Density): Originally a "Conscious Access" idea, I am using more conservative public labels. This estimates whether several things are happening together: fast access-like activity, slower integration-like activity, a delayed relationship between the two, and acceptable artifact/confound levels. A key rule is that missing or bad data stays missing—it never becomes favorable evidence. It is a structural proxy, not a consciousness measurement.
    • CAA (Continuous Autonomic Arrays): Instead of just saying "Target had a lower heart rate than Control," CAA turns HR, HRV, and respiration into continuous time series to ask when the HRV rose, whether the window was long enough to trust, and if respiration drove the change.
    • Micro Handoff: A narrower raw-EEG test asking if a local rise in fast temporal activity is followed by a rise in slower integration-like activity. It is currently treated as software-valid but construct-unvalidated.
    Again, this is exploratory methods software. I am sharing it because I would rather have the hardware and analysis assumptions challenged early than build a private pipeline that only works on my machine.
    Hoyt
    PRAYCG Control Center update: v0.95a → Alpha 10.1.1
    https://github.com/hbanks87/praycg-open/releases/tag/PRAYCG_CC_Alpha_10.1.1
    Hey guys, I wanted to post a substantial update on the PRAYCG project.
    Since v0.95a, it has grown into an end-to-end workflow for designing, running, analyzing and packaging multimodal neuroscience studies.
    The current workflow now covers:
    • Study workspace creation
    • Protocol selection and stimulus preparation
    • AI protocol builder and intake
    • Analysis module/EEG recipe builder and intake
    • Versioning and fingerprinting of protocols, stimuli and settings
    • Hardware-profile creation and equipment checks
    • Synchronized LSL acquisition and LabRecorder/XDF workflows
    • PsychoPy protocol execution
    • Dataset-bound quality control and analysis planning
    • Persistent module-level reports and plain-language interpretations
    • XDF replay and live multimodal monitoring
    • Private and privacy-reviewed research bundles
    • Local research exchange, reanalysis and replication records
    Hardware and acquisition
    The original OpenBCI (Cyton+Daisy) pathways remain supported, including the OpenBCI EEG and optional ALS optical-timing workflow.
    The Hardware Forge has expanded around measurement roles rather than assuming that every user owns the same equipment. It can describe EEG, ECG, EMG, EOG, respiration, EDA, PPG, RR-interval, marker and ALS streams.
    The idea behind the hardware forge is that, ideally, once I have more stream/sync/acquisition scripts worked out for each hardware device, pretty much any consumer/prosumer/professional device would be ready to plug and play with the Control center. Immediate next priorities: Muse S Athena, Cerelog 16 channel version 2 board, Cerelog and OpenBci EMG, and Neurosity Crown.
    Alpha 10.1.1 adds a particularly important interoperability feature: Use existing LSL stream. Researchers can start a compatible vendor application or bridge, inspect its complete LSL metadata, and attach that exact outlet to the current PRAYCG session.
    The selected stream identity, channels, units, sampling rate and original metadata are frozen with the session and reconciled against the resulting XDF during replay, QC, analysis and private bundling. PRAYCG does not claim ownership of or automatically stop external publishers.
    Protocol system
    The Protocol Atlas now contains native PRAYCG protocols, carefully labeled adaptations and exploratory behavioral tasks in the form of Protocol modules. I tried to include adapations for a few popular inner speech decoder protocols, meditation protocols and a few other protocols from narrative/visual/cognitive meaning neuroscience labs. All of the protocols need some work but I thought including some more popular BCI study protocols would be a fun thing to explore.
    Updates to protocol modules:
    • Required materials and hardware roles
    • Fixed or supported configurable timing
    • Pre-start runner configuration
    • Events and response records
    • Compatible analysis expectations
    • Safety, attribution and claim boundaries
    Alpha 10.1.0 introduced a bounded, developerless protocol-extension workflow. A user can describe a study in the AI Protocol Builder, take the generated documentation to an AI assistant for help, and return a strictly data-only protocol definition to PRAYCG.
    The return is checked against the original request, safely rehearsed, reviewed by the operator and installed only after explicit acceptance. Arbitrary downloaded code, dependencies and AI-generated executables are not accepted through this path.
    The motivation for this was I thought that perhaps other folks have interesting protocol ideas of their own and how could I build a way for them to input their protocol ideas, package them for chatgpt 5.6+ review, then have chatgpt have a specific output package that could be imported into the control center as a protocol module expansion.
    I successfully used Gemini AI(because its completely nuts, but in an excellent and poetic way) to hallucinate the "That's a Spicy Meatball" protocol notes in hilarious enough fashion. I inputted these notes into the protocol builder. Created a package and then chatgpt murdered all of the fun out of it but still provided an actual runnable protocol based around cue-based outcome expectancy: testing whether unlikely fictional spicy-versus-mild outcomes produce greater reported surprise and disappointment than expected outcomes, with no actual food, capsaicin, pain or meatball-based betrayal involved. Silly but it demonstrated that the full AI-assisted protocol-return path works.
    Analysis and reproducibility
    The Analysis Forge has changed substantially since v0.95a. It now includes:
    • Required recording-integrity and signal-quality QC
    • Dataset-bound analysis plans
    • Dependency-aware module execution
    • EEG preprocessing and spectral/aperiodic screening
    • Exploratory EEG, autonomic, event and protocol-specific modules
    • Persistent per-module results and reports
    • Automatic offline plain-language interpretation
    • Master reports and provenance records
    • Explicit NOT_ESTIMABLE outcomes when the data cannot support a calculation
    A poor or contaminated recording can still be analyzed descriptively when mathematically defensible, but QC warnings are preserved. Missing evidence is not silently converted into zero, success or a favorable scientific result.
    Research bundles and exchange
    Alpha 10 introduced the first Research Bundle and local PRAYCG DATA foundations.
    A study package can preserve its protocol, stimuli, hardware profile, software environment, raw or standardized data, events, analysis plan, reports and file ledger. Private AI-review bundles may optionally include full telemetry, while public-oriented bundles use stricter exclusions and still require human privacy review.
    Imported bundles remain inert until reviewed. They do not install code, overwrite the original study or automatically grant publication authority.
    The vision behind this: The long-term vision is to make a neuroscience study portable as a complete, inspectable research object not merely an XDF file, spreadsheet or final graph. A recipient should be able to determine exactly what was proposed, what stimuli were presented, which equipment and software were used, what was recorded, how the data were processed, which analyses succeeded or failed, and which conclusions remain uncertain.
    A Research Bundle preserves that chain in a versioned package. A laboratory, independent researcher or curious individual could receive a bundle, verify its contents, replay supported analyses, propose alternative analyses, or conduct a replication without reconstructing the original method from scattered notes and missing dependencies. New work would be linked to and not confused with the original study.
    PRAYCG DATA is intended to become a local-first catalog for those bundles. Public, privacy-reviewed bundles could eventually form a searchable library of protocols, datasets, analyses, replications and reanalyses. Private bundles can instead contain richer telemetry and methodological context for trusted collaborators or an AI system chosen by the user. Importantly, an AI receives the evidence needed to assist with analysis without being allowed to rewrite the historical record or silently install executable code.
    The objective is not to make every uploaded experiment valid or every analysis correct. It is to make assumptions, provenance, missing data, quality problems, analytical decisions and limitations visible enough that other people can evaluate the work for themselves. In that sense, PRAYCG DATA is envisioned less as a repository of scientific “answers” and more as an auditable, reproducible conversation between studies.
  • Hoyt, on your question about making the start pulse longer: a longer pulse may be easier to detect, but one pulse can only tell you the offset at that instant. I’d make a short bench recording with a few identifiable flashes near the start, middle and end of a clip. For each flash, subtract the software marker time from the photodiode edge time after both are on the same clock. Plot those differences against elapsed time. A steady delay, a gradual slope and a single abrupt jump point to different things to investigate. I’d also keep the number of unmatched flashes in the report; a tidy plot can hide a missing event. This could be a repeatable test of a new display or acquisition setup before anyone puts the cap on.
