Cyton Board + Cyton Radio Dongle Cannot Connect After Long Storage — Firmware v1.0.0 Issue?
Hello OpenBCI community,
I would like to ask for help troubleshooting an old Cyton Board with Cyton Radio USB Dongle / RFduino.
I am using an Ultramark III system with a Cyton Board and Cyton Radio dongle. This equipment was purchased for our laboratory before 2018 by my late friend. I am now trying to use it again for my research.
Background
The last time I successfully used this system was around July 2018. At that time, I believe I was using OpenBCI GUI v3.4.0 on Windows. If I remember correctly, there were two executable files: OpenBCI Hub.exe and OpenBCI.exe.
At that time, the software and hardware worked well, and I was able to record EEG data.
However, in 2026, when I tried to use the system again, I could not connect to the Cyton Board and could not record any data.
Main Problem
The OpenBCI GUI can detect the Cyton Radio USB dongle, but it cannot connect to the Cyton Board.
The main warning/error message is:
[WARN]: Found a Cyton dongle, but could not connect to the board. Auto-Scanning now...
CytonAutoConnect: Error reading from Serial/COM port
[ERROR]: Unable to connect to Cyton. Please check hardware and power source.
Complete Console Log
Console Log Started at Local Time: 2026-05-30_10-39-37
Screen Resolution: 1680 X 1050
High-DPI Screen Detected: true
Operating System and Version: Mac - 26.5
MacOS Details: MacOS Catalina
JVM Version: 17.0.6
For more information, please visit: https://docs.openbci.com/Software/OpenBCISoftware/GUIDocs/
OpenBCI_GUI::Setup: GUI v6 Sample Data exists in Documents folder.
OpenBCI_GUI::Settings: Found and loaded existing GUI-wide Settings from file.
ControlP5 2.3.6 infos, comments, questions at https://github.com/retiutut/controlp5
Local Version: v6.0.0-beta.1, Latest Version: v6.0.0-beta.1
GUI is up to date!
Unpacking to: /Users/nugrohobudi/Library/Caches/JNA/temp/libGanglionLib.dylib
Unpacking to: /Users/nugrohobudi/Library/Caches/JNA/temp/libneurosdk-shared.dylib
Unpacking to: /Users/nugrohobudi/Library/Caches/JNA/temp/libsimpleble-c.dylib
Unpacking to: /Users/nugrohobudi/Library/Caches/JNA/temp/libMuseLib.dylib
Unpacking to: /Users/nugrohobudi/Library/Caches/JNA/temp/libBrainBitLib.dylib
Unpacking to: /Users/nugrohobudi/Library/Caches/JNA/temp/libBoardController.dylib
BrainFlow Version: 5.10.0
OpenBCI_GUI: AuditoryFeedback: Loading Audio...
OpenBCI_GUI: AuditoryFeedback: Done Loading Audio!
CP: Playback History Size = 2
sourceList: click!
OpenBCI_GUI: Channel count set to 8
ControlPanel: Found Cyton Dongle on COM port: /dev/cu.usbserial-DB00MEQK
SHUTDOWN HOOK
What I Have Tried
I have already tried the following:
MacBook Air M1
- macOS 26.5
- OpenBCI GUI v6.0.0-beta.1
- Cyton Radio dongle connected using two different USB-C adapters
Windows 10 22H2
- FTDI driver updated through Windows Update
- Cyton Radio dongle connected directly to the USB port
Windows 10 22H2 with older OpenBCI GUI
- OpenBCI GUI v3.4.0
Firmware check attempt using terminal program
I tried using a terminal emulator program on Windows 10:
https://sites.google.com/site/terminalbpp/I read in the forum that sending the
?character through a terminal emulator may show the firmware version.- However, I am not sure whether I did it correctly, or whether this method applies to both the Cyton Board and the Cyton Radio dongle.
Changed COM port number in Windows Device Manager
- I changed the Cyton Radio dongle COM port number from COM7 to COM10.
- I tried connecting again in OpenBCI GUI after changing the COM port.
- The problem still remained, and the GUI still could not connect to the Cyton Board.
Procedure I Used in Each Test
For all tests, I used the following procedure:
- Open OpenBCI GUI.
- Connect the Cyton Radio USB dongle.
- Set the Cyton Radio dongle switch to GPIO_6.
- Turn on the battery to power the Cyton Board.
- Set the Cyton Board switch to PC.
- Use a fresh battery.
- I checked the battery voltage using a multimeter, and it showed around 6.1 V.
- In OpenBCI GUI:
- Select System Control Panel
- Select Cyton (Live)
- Select Serial from Dongle
- Tried both Auto Connect and Manual connection.
Firmware Information
From my previous post in this forum around 2018 , I found that my Cyton firmware version was identified as:
Firmware version: 1.0.0
I have not updated or flashed the firmware yet, because I do not want to damage the board or dongle before understanding the problem clearly.
My Main Question
Could the old firmware version 1.0.0 be the source of this connection problem?
More specifically:
Is Cyton firmware v1.0.0 still compatible with current OpenBCI GUI versions, such as v6.0.0-beta.1?
How can I safely check the current firmware version of:
- the Cyton Board
- the Cyton Radio USB Dongle / RFduino
Any recommended troubleshooting sequence before attempting firmware updates would be very helpful.
Thank you very much.
Best Regards,
nug
Hi Nugroho,
It would be best if your Cyton (mainboard and 2 RFduinos) was running the latest firmware. However, that upgrade process is fairly daunting. I suggest you email to (contact at openbci.com) and open a Customer Support ticket. Point them to this Forum URL so you don't have to retype all of this. They may able to assist in getting your system upgraded. DO NOT attempt to do the upgrade firmware process on your own without their guidance. It also may be possible to exchange your units. Tell them the original purchase information so they can verify their records.
As a stopgap measure, the old GUI versions are available on Github. You may be able to download (say the Windows version).
https://github.com/OpenBCI/OpenBCI_GUI/releases?page=5 use the 'Assets' drop down menu
Hi William, thank you for your kind reply.
yes, I already try the old GUI (3.4.0) in windows, but still doesnt work.
Nug
Just an update after I contacted OpenBCI Customer Support.
OpenBCI Support explained that because my Cyton hardware was manufactured before 2018, it uses older RFduino modules. To make it work with modern OpenBCI GUI versions, the RFduino on both the Cyton board and the USB dongle would need to be completely reflashed using specialized hardware.
Their recommendation is to replace the old Cyton board and dongle with a new unit for better compatibility and more reliable data collection.
Thank You
regards, nug
Hello @nugroho_budi I also struggled with the firmware flashing of the RFduinos. I had to make some minor adjustments to make the compiling and flashing work. I made a post regarding this issue, maybe you wanna have a look here and it might be helpful. https://openbci.com/forum/index.php?p=/discussion/4107/supplemented-tutorial-for-cyton-radios-programming#latest
And of course have a look at the official tutorial for the next steps https://docs.openbci.com/Cyton/CytonRadios/
Since you have the original dongle, that wouldn’t be a big issue at all.
Best regards
Wow, that is a really great tutorial, @danysab! Thank you so much for sharing the link.
I actually haven't done anything with my Cyton hardware just yet, as I'm still struggling a bit with EEG recording on another device. But once I get back to this project, your post will be a huge help. Thanks again!
