Using cEEGrid for trigeminal / jaw reflex electrophysiology
in Cyton
I am exploring the possibility of using OpenBCI cEEGrid together with Cyton + Daisy for advanced neurophysiological studies involving:
- jaw jerk reflexes
- trigeminal dynamics
- silent period analysis
- jaw clenching activity
- peri-auricular EMG activity
- multimodal electrophysiology
I would like to better understand the practical capabilities and limitations of cEEGrid in this context.
More specifically:
- Has cEEGrid ever been used for:
- jaw muscle activity
- trigeminal reflex studies
- jaw clenching detection
- facial or masticatory muscle recordings
What is the practical frequency bandwidth of cEEGrid when used with Cyton/Daisy?
Is the signal quality sufficient for short-latency reflex-related activity?
Can cEEGrid be combined simultaneously with:
- standard surface EMG
- external trigger systems
- piezoelectric reflex hammer synchronization
- electrical stimulation paradigms
- Are there known limitations regarding:
- muscle artifacts
- stimulation artifacts
- temporal precision
- synchronization
- Has anyone attempted multimodal acquisition combining:
- ear-centered EEG
- facial EMG
- trigeminal reflex timing
- jaw activity
Thank you very much.
Frisardi, hi again.
Michael Knierim is the developer and expert on the cEEGrid electrode system. I'm going to mention his profile here on the Forum: @MKnierim , hoping that he might pop in here with some experienced remarks. But if that does not happen, you can click on his blue name above and send him a direct message using the Message button at the upper right area of his Profile.
Hi Frisardi, William,
happy to provide some information. First of all: yes, we have done some preliminary work on jaw clenching activity and peri- auricular EMG activity in general. In those works, differentiating different EMG patterns from cEEGrids worked quite well using a combination of feature engineering and simple machine learning models (like SVM, random forest, LDA):
1. https://www.sciencedirect.com/science/article/pii/S246806722200102X
2. https://link.springer.com/chapter/10.1007/978-3-030-88900-5_6
3. https://link.springer.com/chapter/10.1007/978-3-030-80091-8_4
4. https://www.nature.com/articles/s41598-025-16839-z
If you use the cEEGrids with Cyton+Daisy, you typically work with 125Hz sampling rate, which will give you an effective frequency bandwith of ca. 1-60 Hz; If you'd use a Cyton only, that doubles to 1-125Hz because you can record with 250Hz sampling rate.
Yes, with the cEEGrids you are working with gel - this should be sufficient for short-latency reflex-related activity in my opinion, although this may depend on what you consider as "short-latency". We have more details on timing precision with cEEGrids in this publication: https://www.mdpi.com/1424-8220/23/9/4559
About the combination with other systems: That largely depends on the details. Multi-device EMG recordings should be possible as EMG is passive, so there should be no interference. The rest like trigger signals, etc. depends on your remaining software/hardware stack.
Hope this helps?
Best regards
Michael
Michael @MKnierim , hey thanks so much for your detailed reply with research paper citations !
Frisardi, reply on this thread if you have any followup questions. I also replied on your other thread regarding triggers / stimulators.
Best regards, William
