Problem uploading the PIC32 bootloader
danysab
Germany
Hello dear fellow forum members,
I´m currently trying to uploade the bootloader on the PIC32 (I´m using the one listed on the forum UDB32_MX2_DIP.hex https://github.com/chipKIT32/chipKIT-digiboot/blob/master/BootloadersCurrent-hex/UDB32-MX2-DIP.hex) in order to flash the firmware. I could flash it successfully using a PicKit3 and MPLAB IPE v6.20. So far so good.
The current issue is that I can´t bring the board into bootloader mode (LED is not blinking at all). I tried to bring the board to the dongle as far as i could, checked the voltage and the RFduino on the board is communicating with the one on the dongle (success on GUI). Did you face this issue too and could please someone tell me if there is something i could do to resolve it?
Thanks alot for your help!
best regards
At the end it worked out… somehow the external Quarz was broken. Just changed it and everything went fine. Now the board is successfully running.
