huge numbers while getting data from the cyton
eyaeya Tunisie
i'm working on a bci projcet using the ultracortex markv headset while reading the values coming from cyton and the daisy board i got huge numbers ;( i'm using gui lsl to stream the data with osychopy and lab recorder ); should i rescale this data before preprocessing it and feeding it to the ai model ?
  • eyaeya Tunisie
    As i'm streaming the data via lsl in the gui ; should i rescale the data sent from the cyton or a dc filter is enough ? as it is raw adc numbers not microvolots ?
    Data stream is always in microvolts.
  • eyaeya Tunisie
    edited April 13
    is it normal to have those values while sending from the gui via lsl getting an xdf file(i ve got those values knowing that on the gui a gain*24 is applied and srb2 is on
    Channel min/max :
    Fp1: -10410.794 .. 17889.309
    Fp2: -9606.422 .. 22845.316
    F3: -71080.648 .. -24204.615
    Fz: 187500.000 .. 187500.000
    F4: -73206.453 .. -42476.004
    C3: -71803.055 .. -40817.035
    Cz: -187500.016 .. 187500.000
    C4: -92642.680 .. -58731.645
    T7: -63126.535 .. -10019.013
    T8: -43702.176 .. 2022.520
    P3: -60457.871 .. -3659.361
    Pz: -69417.656 .. -28331.127
    P4: -87337.586 .. -53981.922
    O1: -43063.363 .. -12465.479
    Oz: -38240.773 .. -4481.793
    O2: -80656.445 .. -45190.109
    Did you READ the previous link / search I gave?
    You just need to filter out the DC Offset. Use a high pass or bandpass with a lower limit of .5 Hz.
