Measuring Einthoven's triangle using OpenBCI
The negative of the differential should be on the right arm, and the positive should be connected to the left leg. This is what’s called “Lead II”.
We found that the signal was inverted when we connected the right arm to the positive (upper pin) of the differential input, so in this experiment we switched the right arm connection to the negative input, and the left leg to the positive input.
----> Anybody have any ideas why this is inverted?
Here’s what we did:
Materials:
3 snap electrodes & cables (TDE-205)
3 cloth electrode pads (TD-141C)
note: we have also implemented this with the EEG wet electrodes with similar results.
Connect the reference electrode just above the right ankle, on the inside of the leg.
Connect the differential signal leads by placing one on the inside of the right wrist, with the other end on the “4” positive pin (the pin further from the PCB board).
Connect the other end of the differential signal, the left leg, by attaching the electrode just above the ankle on the inside of the left leg. Connect this to the negative input for the “4” pin on the openBCI board (the pin closer to the PCB board).
Unplug unused leads from the openBCI board, this is a good habit to help prevent interference. Extraneous wires can act as antennas.
Manually turn off all channels except for Channel 4, by clicking on the colored number boxes to the left of the strip chart.
Make sure the amplitude is set to 24x for Channel 4.
On the white settings boxes on the upper right, make sure it’s set to a notch at 60Hz, and Max Frequency is set to 120 Hz.
Set the openBCI unit on your lap. If you set it on a table, it’s likely to pick up interference such as 60hz signals. Holding it on your body will keep it as isolated as possible.
What we saw on the software display
We saw an “upward deflecting R-wave” on the strip chart display for Channel 4. The head showed a blob of activity around Channel 4, as expected. The chart for EEG Data (As received) showed a peak around the heart rate frequency, with a notch at 60hz.
