Alpha/Theta training, help
I want to do Alpha/Theta training.
Which device is recommended. Are there any protocols/ pipelines/ that I can use.
I am pretty technical, and can play with software and programming.
Either Ganglion or Cyton will do neurofeedback protocols. Your choices of apps include:
By using the 'Google Advanced Search' box in the upper right column, you can see past threads mentioning these. Also see:
https://docs.openbci.com/Software/CompatibleThirdPartySoftware/BrainBay/
I searched for prepared design, that I can import to software. For example in opendvibe, and hard to find.
There are a wide range of alpha-theta protocols in the clinical field. But offhand I do not know of any canned design in the above platforms. Basically you want to reward both alpha (8-12 Hz) and theta bands (4-7) simultaneously, each with a different reward sound. This is an eyes closed protocol. Single channel, electrode at Pz with ear lobe as reference. Other ear lobe is ground.
https://www.google.com/search?q=alpha-theta+neurofeedback+crossovers
This small Google Sites page shows a simple alpha reward design.
