Ganglion Channel 4 Producing Abnormal ERP Data (Other Channels OK)
SimonPeiSimonPei South Korean
Hello OpenBCI Community,
I am seeking advice on an issue I'm having with my Ganglion board where Channel 4 is consistently producing abnormal ERP data, while Channels 1, 2, and 3 appear to be functioning correctly.
I have already confirmed that all four DIP switches (SW1-4) on the board are in the DOWN position for standard EEG recording.
The Core Problem
The issue seems to be tied specifically to the Channel 4 input pin (+4) on the Ganglion itself, not the electrodes or cables. No matter which electrode location or physical cable I connect to Channel 4, the resulting ERP plot is corrupted and looks significantly different from the other channels.
Troubleshooting Steps & Evidence
To diagnose this, I have run multiple tests, including swapping the electrode inputs.
  1. Test A: Fp2 connected to Channel 4
    • I connected the Fp2 electrode to the +4 input pin.
    • When plotting the ERPs (P300 and N400), the waveform from Channel 4 is very strange, while the plots from channels 1-3 (connected to other electrodes) look as expected.
    • (See attached image which shows the strange ERP from Channel 4 using these filter settings)
      • P300 filter: 0.2-10 Hz
      • N400 filter: 0.1-30 Hz
  2. Test B: F8 connected to Channel 4
    • To ensure it wasn't a site-specific issue, I then connected the F8 electrode to the +4 input pin.
    • The problem persisted. The ERP from Channel 4 was again completely different and did not show the expected components. The other channels remained fine.
    • (See attached image showing the strange ERP from Channel 4 in this configuration)
      • Filter: 1Hz high-pass, 125Hz low-pass, 50Hz notch
To be clear: when I connect the Fp2 or F8 electrodes to any other channel input (e.g., +1, +2, or +3), they produce normal-looking data. The problem only occurs when an electrode is plugged into Channel 4.
My Questions
  1. Given that the problem stays with the Channel 4 input pin regardless of the electrode used, does this strongly suggest a hardware fault with that specific channel on my Ganglion board?
  2. Has anyone experienced an issue where a single channel on a Ganglion fails or produces consistently noisy/bad data while others work fine?
  3. Are there any other software settings, firmware issues, or hardware configurations I should check that could cause just one channel to malfunction like this?
Any insights or suggestions for further testing would be greatly appreciated. Thank you!
    Please email to contact at openbci.com, which is the customer support email. They can suggest how to proceed if this is confirmed as a hardware issue.
  • SimonPeiSimonPei South Korean
