Cyton Board Unresponsive After Baud Rate Set to 921600
in OpenBCI_GUI
Hi everyone,
I'm new to OpenBCI and currently trying to increase the sampling rate to 1000 Hz by modifying the firmware. I'm using a USB-TTL connection to the Cyton board.
After increasing the baud rate to 921600, I noticed that the Cyton board became unresponsive—specifically, the slide switch no longer seemed to work.
Has anyone experienced this issue or knows why this might be happening?
Any help on how to resolve this would be greatly appreciated!
Thanks in advance.
Cindy, have you tried reloading the factory, default, normal firmware? Before proceeding further, I suggest you email as instructed below.
Once reloaded with the normal firmware that should fix your issue. Be extremely careful with custom firmware. Some users have been known to 'brick' their boards if they manage to destroy the chipKIT bootloader.
Yes, I tried to reload the default firmware, but I can't launch the Cyton board because of the issue.
I've checked the Programming Tutorial instructions and followed them to set up the firmware, and be careful with the chipkit download version as well as the bootloader mode. I'm afraid that the board is now a brick, but still hoping to get to know which step has caused this consequence or any solution that can manage to save this board.
Here are the codes I've adjusted:
Library.cpp
curSampleRate = SAMPLE_RATE_1000;commented out the following:
Library_Definitions.h
#define OPENBCI_BAUD_RATE 921600Please email [email protected]
Ok thank you for the assistance, I’ve send the email.
