GUI for ganglion hangs at Starting Session [resolved]
I´m using the Ganglion board with the openBCI GUI on a Windows PC. The software gets stuck and hangs when trying to start the session. It says ´Starting Session´ but never actually starts. I tried some things:
Happens on Windows 10 and 11, both with and without running as admin.
Happens with two different bluetooth receivers, and on two different ganglion boards. All of those do actually function properly on different windows PCs.
Happens with both the GUI application standalone as well as through the processing app.
Tried reinstalling several times, no luck unfortunately.
Would you have any idea what it could be or what I could try?
Thanks!!
Processing throws a NullPointerException error...
OpenBCI_GUI: Channel count set to 4
[DEFAULT]: Refreshing available Ganglions using BLED112 Dongle...
ControlPanel: Found BLED112 Dongle on COM port: COM4
OpenBCI_GUI_Helpers Version: 2.0.1
bleList: click!
[DEFAULT]: Ganglion Device Name = Ganglion-a1d0
|| INITIALIZING SYSTEM ||
MAC address for Ganglion is c8:11:b7:6b:4b:09
[DEFAULT]: Detected Ganglion firmware version 2
Sending config string to board: n
Unpacking to: C:\Users\NEUROP~1\AppData\Local\Temp\jna-1116465799\onnxruntime_arm.dll
java.lang.NullPointerException
at java.base/java.util.Objects.requireNonNull(Objects.java:209)
at java.base/java.nio.file.Files.copy(Files.java:3128)
at brainflow.JarHelper.unpack_from_jar(JarHelper.java:31)
at brainflow.MLModel.(MLModel.java:46)
at OpenBCI_GUI$W_Focus.initBrainFlowMetric(OpenBCI_GUI.java:24883)
at OpenBCI_GUI$W_Focus.(OpenBCI_GUI.java:24670)
at OpenBCI_GUI.setupWidgets(OpenBCI_GUI.java:31734)
at OpenBCI_GUI$WidgetManager.(OpenBCI_GUI.java:31824)
at OpenBCI_GUI.initSystem(OpenBCI_GUI.java:849)
at OpenBCI_GUI.systemInitSession(OpenBCI_GUI.java:1117)
at OpenBCI_GUI.draw(OpenBCI_GUI.java:654)
at processing.core.PApplet.handleDraw(PApplet.java:2094)
at processing.opengl.PSurfaceJOGL$DrawListener.display(PSurfaceJOGL.java:840)
at com.jogamp.newt.opengl.GLWindow.display(GLWindow.java:782)
at com.jogamp.opengl.util.AnimatorBase.display(AnimatorBase.java:453)
at java.base/java.util.TimerThread.mainLoop(Timer.java:566)
at java.base/java.util.TimerThread.run(Timer.java:516)
file: onnxruntime_arm.dll is not found in jar file
Unpacking to: C:\Users\NEUROP~1\AppData\Local\Temp\jna-1116465799\onnxruntime_arm64.dll
at brainflow.MLModel.(MLModel.java:47)
file: onnxruntime_arm64.dll is not found in jar file
Unpacking to: C:\Users\NEUROP~1\AppData\Local\Temp\jna-1116465799\onnxruntime_x64.dll
Unpacking to: C:\Users\NEUROP~1\AppData\Local\Temp\jna-1116465799\onnxruntime_x86.dll
Unpacking to: C:\Users\NEUROP~1\AppData\Local\Temp\jna-1116465799\MLModule.dll
[SUCCESS]: Marker Widget: Listening for markers on 127.0.0.1:12350
SessionSettings: 4 active widgets saved!
[SUCCESS]: Session started!
Unpacking to: C:\Users\NEUROP~1\AppData\Local\Temp\jna-1116465799\DataHandler.dll
And the standalone version console log says:
at java.base/java.util.Objects.requireNonNull(Objects.java:208)
at OpenBCI_GUI$W_Focus.initBrainFlowMetric(OpenBCI_GUI.java:24885)
at OpenBCI_GUI$W_Focus.(OpenBCI_GUI.java:24672)
at OpenBCI_GUI.setupWidgets(OpenBCI_GUI.java:31736)
at OpenBCI_GUI$WidgetManager.(OpenBCI_GUI.java:31826)
java.lang.NullPointerException: Cannot invoke "ddf.minim.ugens.Gain.setValue(float)" because "this.this$0.auditoryNfbGains[i]" is null
at OpenBCI_GUI$AuditoryNeurofeedback.update(OpenBCI_GUI.java:2229)
at OpenBCI_GUI$W_Focus.updateFocusState(OpenBCI_GUI.java:24837)
at OpenBCI_GUI$W_Focus.updateFocusWidgetData(OpenBCI_GUI.java:24970)
at OpenBCI_GUI$DataProcessing.process(OpenBCI_GUI.java:9341)
at OpenBCI_GUI.processNewData(OpenBCI_GUI.java:9074)
at OpenBCI_GUI.systemUpdate(OpenBCI_GUI.java:1046)
at OpenBCI_GUI.draw(OpenBCI_GUI.java:649)
Just solved it! The audio NullPointerException error was more serious than I thought. I don´t need it, but simply plugging in a cheap pair of speakers solved all the issues! I guess the gui was trying to play sounds during connection with the board. Without speakers it got stuck there
It actually tries to load sounds into memory, which it's unable to do if a sound device is not detected in the system. I believe we have just implemented a fix for this.
Richard @retiutut, see a recent Linux user thread with the same issue. Null pointer exception due to missing audio.
https://openbci.com/forum/index.php?p=/discussion/4051/cannot-connect-to-cyton-linux#latest
