Pulse Sensor with Ganglion ?
I just want to verify whether the heart rate sensor is compatible with the Ganglion? I've mentioned this before (sorry about this I took a long time off from this), but I just want to verify whether the sensory can be used, and if it indeed is able to display ECG pulses, or if it just displays BPM and HRV?
Thank you ![]()
Hi Austin,
The Pulse Sensor can be used with Cyton or other Arduino based controllers. But it does not connect directly to Ganglion.
Ganglion DOES do conventional ECG, as you can see in the image just above this section:
https://docs.openbci.com/GettingStarted/Boards/GanglionGS/#connect-yourself-to-openbci
This is the Pulse Sensor doc at OpenBCI:
https://docs.openbci.com/ThirdParty/Pulse_Sensor/Pulse_Sensor_Landing
And there are a range of docs on Joel Murphy's site:
https://pulsesensor.com/pages/pulsesensor-manual
https://pulsesensor.com/pages/installing-our-playground-for-pulsesensor-arduino
