Shows that the cEEGrid flat connectors slide into the two sides of the adapter. Then you must (manually) run jumper cables from output pins on the adapter, to the input pins on Cyton / Daisy. See 2nd link above for wiring. These pages are also helpful.
Here are the related docs:
https://docs.openbci.com/ThirdParty/cEEGrid_Kit/
https://github.com/MKnierim/openbci-ceegrids [this is the main manual page for wiring jumpers]
https://uol.de/psychologie/abteilungen/ceegrid
https://uol.de/en/psychology/neurophysiology/resources/ceegrid-video-tutorial
https://uol.de/neuropsychologie/howtoconnect
https://uol.de/neuropsychologie/howtouse
This photo:
https://shop.openbci.com/products/ceegrid
https://docs.openbci.com/GettingStarted/Boards/DaisyGS/
Thank you :-)
I would add one more, telling what to do with Y-spliter cable: https://shop.openbci.com/products/ultracortex-mark-iv
Still, in case of CEEGrid, do I need to use that Y-splitter cable? CEEGrid set seems to contain referencial electrode. Is here anyone using CEEGrid?
Piotr, hi again.
Did you read the entire 2nd link previously given:
That has complete instructions for wiring the jumpers. The Y-cable is covered.
Brilliant !!! Thank you very much , I was in hurry reading it and missed that completely...
