Search for Zengar Electrodes
Good morning!
Do you know where I can find Zengar's electrodes? I have a neuroptimal® and I don't get electrodes, because they don't let them send,
Do you know of any distributors in Europe?
Thank you
This discussion has been closed.
Hi Sp87,
Note that you are on a Forum devoted to OpenBCI hardware / software. Nothing to do with Zengar products.
As far as I was aware, Zengar was using standard EEG cup electrodes, nothing fancy. Not sure the type of metal used however, EEG cup electrodes can be either gold plated, solid silver or solid tin. You obviously want to use the same metal they chose. Zengar also uses cup based ear clips, spring loaded. All these types of electrodes are widely available on the web by just searching on EEG electrodes.
He does not use cup electros, he uses silver-plated flat-tip electrodes, and there are 3 tweezers.
And two flat sensors, I can't find them.
Can you give me a link, please?
All my best.
Look, this Forum has nothing to do with Zengar. Please search on other forums.
My impression is that he originally used cup electrodes since those are more widely used. You can also find the flat type online. I cannot do Google searches for you. There is basically no difference between cups and flat EEG electrodes other than the shape. Both perform the same with paste. But cups have a slight advantage over flat, in that the paste adheres better because it has more surface area and more paste volume.
