Trouble Launching OpenBCI GUI Application from Unity Script
This picture is the code.
I can used the code to open all of application(folder,browser....)except OpenBCIGUI,how to fixed it thanks.
Mentioning Richard @retiutut.
Can you please share the full error that is produced in the Unity Console Log?
It doesn't show any error beacuse i can run it normally. I think Unity also assumes it has executed successfully,but in reality,GUI hasn't launched.
@retiutut I'd be very grateful if you could help me.
Are you sure the embedded spaces in your filename / pathname are not causing issues: "...\OneDrive - xxxxxxxx\..."
Conversely, are you sure you need to double the backslashes if they are enclosed in quotes?
Is that path going out to OneDrive, or is it something you have copied locally? Have you tried just doing everything local to your own harddrive?
I've tried installing the GUI on c:,but it still won't open.
Must use double backslashesor it will display an error.
