BioEra and Ganglion Firmware v3.0 [resolved]
2»
  • Hi, I am trying to activate the simulated square signal using the "[" command, but that doesn't seem to work as before? Is this an intended change to the firmware 3.0.1?
  • Thanks for reporting this - it looks like a bug. I suspect the synthetic mode is still sending data using the v2 packet format.
    I'm logging it here and will take a look at it as soon as possible. I'll be out of the office for a couple weeks, but will take a look at fixing it as soon as I'm back.
  • BioEra v. 4.218 now supports all versions of Ganglion including those with latest firmware 3.0.1.
  • Hi Jarek,
    Thank you for your continued support and dedication!
    @jarek, fantastic, Bravo !
    I think @philip_pitts, @Shirley and myself will join other staff at OpenBCI in thanking you for your generosity and dedication to excellence.
  • The issue @jarek reported regarding bad synthetic mode data has been resolved in v3.0.2 of the Ganglion firmware.
    Thank you for all your work Jarek!
