Hi, I am trying to activate the simulated square signal using the "[" command, but that doesn't seem to work as before? Is this an intended change to the firmware 3.0.1?
Thanks for reporting this - it looks like a bug. I suspect the synthetic mode is still sending data using the v2 packet format.
I'm logging it here and will take a look at it as soon as possible. I'll be out of the office for a couple weeks, but will take a look at fixing it as soon as I'm back.
BioEra v. 4.218 now supports all versions of Ganglion including those with latest firmware 3.0.1.
Hi Jarek,
Thank you for your continued support and dedication!
@jarek, fantastic, Bravo !
I think @philip_pitts, @Shirley and myself will join other staff at OpenBCI in thanking you for your generosity and dedication to excellence.
The issue @jarek reported regarding bad synthetic mode data has been resolved in v3.0.2 of the Ganglion firmware.
Thank you for all your work Jarek!
