Connecting electrode cap with Ganglion or Cyton board
SaimaSaima Pakistan
edited December 2022 in Cyton
I am using OPENBCI EEG cap (cyton and daisy board).I am trying to connect my Electrodes with boards. but i am unable to connect it properly and i couldn't find any connection with these four pins....please help as i an new to it.
    Saima, hi.
    Are you following the tutorial? You will need to have the adapter cable that converts between the cap 'touchproof' connectors and the header pin connectors used on the boards.
    https://docs.openbci.com/AddOns/Headwear/ElectrodeCap/
  • SaimaSaima Pakistan
    Wiliam ,Hi
    I had adapters with which i connected the rest of the cables circled with blue in the image but i have some black pins left to connect with the boards circled as yellow in the image and some electrodes wire which need to be connected to adapters marked in red.............Sir i hope i am clearly explaining my issue...
    Wiliam ,Hi
    I'm sorry I'm not clear on your last comment. You also made SIX duplicate comments, is your computer working ok?
    Another good option is for you to simply email customer support at (contact at openbci.com).
    ok......Thank you so much for your time and support
