Is a Different Sampling Rate Possible for the Ganglion? E.g., 125 Hz or 250 Hz?
in Ganglion
Hi All,
Is it possible to change the sampling rate on the Ganglion to something other that 200 Hz? Either 125 Hz or 250 Hz would be ideal.
I assume that one could modify the firmware to do this. Or is there some sort of hardware limitation?
Max
"~(COMMAND)
This works similar to the Channel
Settings commands, however, there is no latching character. Power
cycling the OpenBCI Ganglion board will cause the sample rate to reset
back to default of 250Hz."
Hello, everyone, I would like to know how, using the WIFI Shield, one can change sample-rate for the Ganglion board.
Thanks
Gabriel
https://docs.openbci.com/Ganglion/GanglionSDK/#sample-rate
