Cyton + Daisy build / TVS diode polarity ?
teknomage
UK
Hi, I'm attempting to build the Cyton and Daisy boards on my own.. going down the hand-soldering route. I got the PCBs printed and managed to procure all the required components as well. I decided to start easy, so I began putting together the Dongle based on RFD22301. Managed to solder almost all the components in place, except for a couple of them.. specifically, the ESDALC6V1-1M2 (TVS diode) and the CG0402MLC-05LG varistor. The problem I'm facing here is that these components I received from China dont have the polarity marked on them, unlike the way they're depicted in the datasheets. I'm assuming there shouldn't be a problem of polarity with the varistor, correct? But for the TVS diode, I am unable to find any marking that would indicate the cathode.. and I cant differentiate between its terminals, even though I did a simple continuity test.
I know this sounds like such a noob question but is there any other way I can determine the polarity of the TVS diode?? I dont want to solder it incorrectly and then fry something on the board in the process, lol
I will have further questions down the line, but I need to get this sorted out first.
https://www.google.com/search?q=determine+the+polarity+of+the+TVS+diode
Datasheet says the TVS you mention is unidirectional,
https://www.st.com/content/ccc/resource/technical/document/datasheet/a7/45/14/0d/75/ec/42/b9/CD00110945.pdf/files/CD00110945.pdf/jcr:content/translations/en.CD00110945.pdf
So if these were supplied as cut-tape, then your supplier goofed by not indicating polarity. They should then owe you a replacement. Maybe faster would be to order from Digikey or some decent distributor.
https://www.digikey.com/en/products/detail/stmicroelectronics/ESDALC6V1-1M2/1122291
The ST datasheet does show a drawing of the cut tape with polarity indicated.
Thank you very much for all the detailed info, Will.. much appreciated!
