Does anyone have BrainBay designs (protocoles)?
There are BrainBay Configurations built in Neurobit systems devices - I was wondering if you know how we can access to them if we do not have those devices ( I am using Cyton )
Thank you!
If you want actual neurofeedback protocols, guided by an assessment / brain map, Brain-Trainer (BioEra based), supports Cyton and Ganglion. This is not based on BrainBay, but instead on BioEra, which is licensed with a separate dongle. BioEra is the basis for many commercial packages such as LENS, Cygnet, etc.
Thank you very much for your answer.
I have tried the examples you sent but the signal I am receiving a wrong signal.
I think I have a problem in the filter or in the source element I am adding.
I am using Cyton Biosensing Board (8-channels)
Could you please advise which source element I need to add, which Baud Rate, filters, ...
Thank you very much
This example comes with pre-defined element blocks. The COM port information in the element block just needs to be updated with the current dongle COM port number. The other info such as baud rate should stay the same.
The other example shows a neurofeedback protocol that rewards alpha and inhibits beta. Same idea, just alter the COM port.
Laura, hi.
This is a tutorial I put together some time ago,
Also see,
https://docs.openbci.com/Software/CompatibleThirdPartySoftware/BrainBay/
https://brain-trainer.com/product/brain-trainer-interface-bundle/
https://brain-trainer.com/product/brain-trainer-bioera-basic/
http://www.bioera.net/index.shtml
There are a number of designs included with the BrainBay download / install. I believe these are documented in the manuals.
Thank you very much
Did you look at this example?
https://sites.google.com/site/biofeedbackpages/brainbay-openbci/spectrogram
