Which column holds the raw ECG data?
Hello All,....@wjcroft, @retiutut
Hope you're doing fine. I recorded ECG data on **Channel 3 **using the 8-Channel Cyton board. I exported the raw txt data to excel. Pls which of the columns contains the actual ECG data? I want to denoise the signal in Matlab/python, what filters (order, bandpass, etc) do you recommend, and at what sampling frequency?
I am really grateful for your time
In computer science, we often start counting from 0. As you can see in the photo, there is data in "EXG Channel 2" column. This data is the raw, unfiltered data. If you wish to load this into another program, you would need to apply the desired filters to see what you saw in the GUI when making the recording, such as bandpass and bandstop filters.
Thank you for your time
