I want to connect the Dry EEG Comb Electrodes to the Cyton board, but I cannot find a purchase link for the cables for connection. Is there any other way to connect them? Thanks.
Note that the FRI page leads terminate in a 'touchproof' connector, rather than the Berg / Dupont connector that mates directly with the header pins. You can either purchase the touchproof adapter cable in the Shop, or cut off the touchproof and splice on a Berg from a jumper cable.
The headband kit contains five leads that clip onto the FRI combs,
https://shop.openbci.com/collections/frontpage/products/openbci-eeg-headband-kit?variant=8120393760782
More can be had from FRI,
https://www.fri-fl-shop.com/product-category/leads/fri-leads/
https://www.adafruit.com/category/306
Thank you so much!
