How to turn off SRB2 of Cyton-Daisy board using Python?
I'm conducting EEG studies using Cyton-Daisy board (16channels).
I need to record additional ECG signal so i 'm planning to one of my EEG channel to ECG.
(15 EEG channels and 1 ECG channel)
I tried 3-Lead ECG setting from https://docs.openbci.com/GettingStarted/Biosensing-Setups/ECGSetup/.
Before turn off the SRB2 of ECG channel, data from the other 15 EEG channels looks like ECG.
By using OpenBCI_GUI, I could turn off SRB2 of my ECG channel.
But I was hard to find it when using Python code to record.
Almost documents about it were 'Deprecated'.
In my Python code, I'm using brainflow libraries for simple recording.
board = BoardShim(board_id, params)
board.prepare_session()
board.start_stream()
data = board.get_board_data()
Is there any way to turn off SRB2 of specific channels by using Python?
I could not find it from docs of brainflow..
There was a few mention about 8bit command to adjust each channel setting but I could not find how to do it because almost docs were 'Deprecated'.
Or, I need to find other ways to do it unless using Python.
Thanks.
Jaehyung, hi.
See,
https://openbci.com/forum/index.php?p=/discussion/2703/sending-cyton-sdk-commands-with-brainflow-resolved
and
https://www.google.com/search?as_q=config_board&as_sitesearch=openbci.com
Another easy trick to learn what commands to send to Cyton is to:
Also, you can send more than one channel setting command in an all-at-once manner. Here's an example which is actually the default channel settings for Cyton.
Though practically, resetting the Cyton board can be done more easily by sending
d.Take Care,
RW
Hi, there
I really appreciate your help. I could solve my problem easily due to both of you.
Thanks a lot.
