Accurate data from ganglion to neuromore (without brainflow)?
I'm trying to get accurate data into neuromore from OpenBCI. I have the ganglion with bluetooth dongle, which neuromroe can't detect. I've tried using branflow, but I just can't understand how to get it to work (step by step guide, please). What I've been doing now is:
Record data from OpenBCI -> import .txt file into matlab -> export EXG channel 1-4 as .csv -> import .csv to neuromore.
However, the imported data seems kinda choppy and off compared to the signals I get from neuromore's test system. The numbers outputtet are also so big that it is really hard to work with.
Is there a way to import a accurate representation of the graphs in OpenBCI to a spectrum neuromore easily can read?
Thank you.
Sandre, hi.
My understanding was that neuromore now supports Ganglion streaming directly from the BLED112 dongle, using Brainflow libraries. Are you sure you have the latest neuromore? Have you tried contacting neuromore support?
Your Ganglion works fine using the latest OpenBCI_GUI?
In previous editions of neuromore, it was possible to use the GUI Networking Widget to output a stream in OSC format, which neuromore can receive. But that should be obviated by the new capability of neuromore to talk directly to the BLED112 / Ganglion via Brainflow.
Thank you, wjcroft! That worked perfectly.
I can't believe I didn't know about it. It felt like I scoured the whole internet for a solution.
Hi again, wjcroft
Since I have already recorded my experiment through the OpenBCI GUI, is there a way to network it through brainflow to neuromore? Using OSC input directly to neuromore only seems to give me 1 channel
