Question on format not matching for SD Card log as described
Hi All,
I was looking into the SD Card log, and as per OpenBCI Documentation I was supposed to get it in the below format:
But my SD Card log is coming in this format:
Also I am not seeing last set of packets described in the documentation that should be present, as show below:
NOTE: I am using OpenBCI GUI for recording the data with SD Card, and the OpenBCI Headset is NOT WORN.
My Question is:
1. I am only getting STOP packet on my SD Card log file, and unable to see any START packet, what can be the issue?
2. I am also not able to see Time packets that should be present at the end of my SD Card log, where am I going wrong?
@wjcroft, @retiutut, I would be really thankful for you help on this.
Pluto
For reference: I am using Firmware version 3.1.2.
I am also getting this issue, for v3.1.1.
https://github.com/OpenBCI/OpenBCI_GUI/issues/893 I've added a link to this thread to an open issue to re-investigate and confirm Cyton SD card recordings.
