Sleep study / EDF acquisition or conversion
We have just purchased the OpenBCI 16-channel R&D kit. After following the setup instructions, we were able to record EEG, ECG, and EKG signals!
One of the projects we would like to use this system for is in a sleep study. Are there any other research groups that use OpenBCI for sleep studies? We would like to carry out a polysomnography (PSG). Does OpenBCI offer a PSG analysis software? Does anyone know of any open source PSG software that can be integrated with OpenBCI? Or any other information on how we can set one up?
Thanks for the support!
If someone has used/converted to EDF format previously, how can the signals from the OpenBCI system be converted into EDF format?
http://www.teuniz.net/edfbrowser/
Brainbay can also output in EDF, as can BioEra.
Also, you've probably seen this, but lots of utilities on this page,
http://www.edfplus.info/downloads/index.html
The world really needs to begin investigating blockchaining (sp?) EDF recordings. This is needed because EDF can be exported to ASCII, the ASCII edited and then imported back into EDF, providing a venue to alter and/or compromise these medico-legal recordings. As well, another needed process would be to watermark the recording via embedding invisible known frequencies at known power levels (e,g, 40hz @ 2% total power for x ms) into the recording so that only later analyses (FFT) can determine if said signals are present. This process would use a code to set the watermark of the recording, and this code could also be the seed value for the second by second blockchain process. I am speaking in the bigger picture than just OpenBCI makers. Like the powers that be should mandate EEG/Sleep recording system to lock their recordings with these type of processes.
Why would anyone have access to the original of EDF file without proper authorization? That is a privacy issue.
As it stands, being able to alter the identifying data on a digital EEG is nice because it allows the sharing of anonymized files for research.
