Ganglion using Matplotlib to graph, produces weird results ?
bruvbruv Houston
edited July 2021 in Software
I just graphed the time series data of a Ganglion board EEG recording from channel 1 and got the following plot (EEG vs time). Has anyone else gotten this before? What am I doing wrong as this clearly isn't a waveform.
  • Should you have both an x vector and a y vector in your plot() statement?
  • bruvbruv Houston
    I tried and I still got the same graph.
    The lack of an x vector isn't the problem since plt.plot() just uses the indices of the argument as the x variable as default if only one argument is given.
    Bruv, hi.
    Bill, thanks.
    You can access the Ganglion board directly in real-time from Matlab, using Brainflow,
    https://brainflow.readthedocs.io/en/stable/Examples.html#matlab
  • bruvbruv Houston
    Is there a way to do the same thing in python?
    Read through the docs, multiple languages are supported,
    There is a Slack group for questions, sign up via link on this page,
    https://brainflow.org/
  • edited July 2021
    The graph appears to be a line graph composed of 2 components. One, the bottom of the vertical lines, is a somewhat sinusoidal graph, and might be data. The other is a linearly increasing function which might be time points. Why your plot could be drawing nearly vertical lines between 2 perhaps alternating sets of data is the question.
  • bruvbruv Houston
    I agree Bill. It's interesting that the baseline from which the sinusoid returns to each cycle is linearly increasing. I wonder if this is a result of a recording artifact.
  • If the data was not just voltage readings but was a time measure (as in the time() computer function) interleaving somehow with a microvolts type EEG voltage reading, it might look like this.
