question on BrainFlow gain change with ThinkPulse electrodes
I get an issue regarding changing gain values of each electrode because of using ThinkPulse™ Active Electrode Kit.
- According to the instruction, I should set the gain value of each electrode from x24 to x8 or less (https://docs.openbci.com/ThirdParty/ThinkPulse/ThinkPulse/#troubleshooting).
- Regarding the gain value of each electrode, the manual of OpenBCI says that I should check of scale factor; however, also, the manual say that BrainFlow supports automatically re-scale since Jan 2021 (https://docs.openbci.com/Cyton/CytonDataFormat/#interpreting-the-eeg-data).
- When I sent a command for changing a gain value of electrode (e.g., "x3040010X") in BrainFlow-python bind, I saw a warning message.
Question: In order to use ThinkPulse™ Active Electrodes, I should set gain value as 8 or 5 by sending a command to a Cyton board. In that case, should I set value on certain variable or call some functions of BrainFlow? or do some extra calculations when I get data (e.g., "data = (board.get_board_data())[board.get_eeg_channels(0),:] * ???")?
P.S I am confusing that asking this question in this Forum is proper or not. If my question is not proper in this forum. I would like to apologize.
you can multiply by 24 and divide by your new gain to get real value from the body
Hi, Jrseojr,
I believe @Andrey1994 (BrainFlow developer) may have some insights into the warning you are seeing.
You can also ask questions on the BrainFlow Slack, sign up via page below. But I think Andrey will see your question here on the Forum.
https://brainflow.org/
@wjcroft and @Andrey1994
Thanks for answering.
Ah... I have an additional question for the Cyton board and OpenBCI-GUI.
As I mentioned above, I should use ThinkPulse™ Active Electrodes. Therefore, following the instruction of ThinkPluse, I set all electrodes' gain value as x8 in the hardware setting widget of OpenBCI-GUI.
In that time, OpenBCI-GUI sent a command to Cyton board "x1040010X", "x2040010X", , , , "x8040010X".
When I compare saved files (collecting EEG in x8 gain and x24 gain / same condition), all electrodes' uV values were different.
Question for @wjcroft : If I only change gain value of electrodes in the Cyton board by sending the serial command (condition is using ThinkPulse electrode), I don't have to do anything on OpenBCI-GUI, and should I just use uV value of saved files without extra calculation?
Question for @Andrey1994 : I have a question regarding your answer; however I will ask it on BrainFlow slack
Cheers
J.
Yes I believe if you change the gain in the GUI, the recording file always shows the correct microvolts.
Richard @retiutut, can you comment on the recording microvolts values when the gain is changed in the GUI?
