Silicone Electrodes
Hi Folks.
Just an idea. Often when doing special effects makeup one needs to put on fake scars etc. These are usually made with silicone and glued on with Pros-Aide (a very common glue for this)
This made me think - as the 'scars' need to be flexible on the actors skin, but also needs to stay attached, then they might make an excellent bed for embedding electrodes in.
The silicone is an insulator, and can be washed many times.
For example, several electgrodes can be embedded in the forehead/eyebrow section and thus record the fEMG there.
Just an idea - it might also help re complex arrangements of fixed electrodes.
Dave
I tried playing around with the Neurosky chip that was in a Mindwave game. Was able to get both the normal and raw data from it. The big issue with EEG is that it's difficult to get a consistent result in an ad-hoc environment. When you are running around, talking with people, interacting, and then need to control your thinking to make a semi-precise move it starts to fall apart.
Cost is also an issue as this is for amateurs, plus time and set up. Reusable electrodes offer a good way to save on cost, and having a pad that already has 2 (or more ) electrodes embedded in it would help greatly.
For example if one was to monitor 8 muscles then that would be 16 + 1 electrodes. That's a lot of reusable pads to go through.
I've found these Dry Electrodes that can have a spot of conductive gel placed in them.
On a side note - rummaging through my boxes of electronic bits I found 5 old boards from AdvancerTechnologies that will serve as a test bed until I get the OpenBCI board in. Unfortunately due to exchange rates is'd nearly $700AUD
Many thanks for all your helpful tips etc.
Dave
