Cython board two line input pins
Hello, I recently acquired the cython board. I noticed that it has two lines of input pins and I got the impression from the specs that I should connect the electrodes on the upper line of pins even tho I don't see any mention of the actual difference between each line. Is there any difference at all?
Check out the Cyton tutorial, and other tutorials,
https://docs.openbci.com/docs/01GettingStarted/01-Boards/CytonGS
https://docs.openbci.com/docs/01GettingStarted/02-Biosensing-Setups/EMGSetup
The default set of pins are the 'bottom', or closest to board surface. The 'top' pins are used when the channel is in differential mode, as in most EMG applications.
