What is the fastest way (less latency) to import Live EEG stream from Cyton Board to MATLAB 20a We are working on SSVEP project
(I donot have WIFI Sheild)
This # Method 2 is not working.. giving errors in MATALB in build mex
Please consider using Brainflow instead of LSL. Also by avoiding streaming the data first through the GUI Networking Widget, latency is further reduced.
Hasni, hi.
https://brainflow.org/
https://brainflow.readthedocs.io/en/stable/Examples.html#matlab-get-data-from-a-board
We should update the Doc found here: https://docs.openbci.com/docs/06Software/02-CompatibleThirdPartySoftware/Matlab#method-2-stream-openbci-data-via-lsl
I have made an issue with this information. Hope to update this soon!
https://github.com/OpenBCI/Documentation/issues/58
_Till here i have done.. after wards i know nothing.. kindly help...
_
You can use the GUI to find the name of the Cyton Dongle serial port on all OS.
Plug in dongle -> Open OpenBCI GUI -> Control Panel -> Cyton -> Manual -> See list of all connected Cyton Dongles
Thankyou
Thankyou
