Cyton SDK - how to turn off test signal [resolved]
grahambriggsgrahambriggs Corvallis
edited February 2021 in Cyton
Can anyone shed more light on the 'Test Signal Commands' that are described in the Cyton SDK.
https://docs.openbci.com/docs/02Cyton/CytonSDK
I have been successful to set the different test signal commands and see the results on a plot. So far so good. However, I have to power cycle the system to get out of this mode. Is there a command to exit test signal mode and return to normal operation?
    Hi there,
    https://docs.openbci.com/docs/02Cyton/CytonSDK#default-channel-settings
    "d To set all channels to default"
    If you're in the GUI, you can do Settings -> Expert Mode On. Then, open Cyton Hardware Settings -> Send Custom Command UI -> d -> Send Command. Alternatively, you can close the session and open a new one.
    I would hope this command does the trick. In some edge cases, the board may still need to be turned off and back on.
    From the BoardCyton class in the GUI:
        public BoardCyton() {
            // The command 'd' is automatically sent by brainflow on prepare_session
            currentADS1299Settings = new CytonDefaultSettings(this);
            useDynamicScaler = true;
    Hope this helps,
    RW
  • Thanks, This makes sense. I will look into the d command.
