I am just trying now to stream to openVIBE. It does not work.
I follow your instruction in another post. I already activated the widget and start LSL.
For openvibe designer, I chose LSL. Yet, it gave me this result
SHould I open in another thread for this question ?
Have you instead tried to stream directly from the Cyton? (First section of page above.) If GUI LSL is not working, it sounds like your Networking Widget is not setup correctly.
Thanks for that....
Thanks
Hi @ihgumilar, I split your LSL question into a new thread.
Are you following the suggestions in this docs page:
https://docs.openbci.com/docs/06Software/02-CompatibleThirdPartySoftware/OpenVibe
https://docs.openbci.com/docs/06Software/01-OpenBCISoftware/GUIWidgets#networking
https://docs.google.com/document/u/1/d/e/2PACX-1vR_4DXPTh1nuiOwWKwIZN3NkGP3kRwpP4Hu6fQmy3jRAOaydOuEI1jket6V4V6PG4yIG15H1N7oFfdV/pub
https://docs.openbci.com/docs/06Software/01-OpenBCISoftware/GUIWidgets#lsl
Some related threads, using the search button "Google Advanced Search" in upper right column.
https://www.google.com/search?as_q=lsl+openvibe&as_sitesearch=openbci.com
thanks
