Cyton hardware settings
Hello. I couldn't find information on Hardware settings could you explain what this is for or throw a link where I can read it, thank you in advance.
Also interested in the question of how to send a test signal and check the performance, again, I did not find the information. I use a Board of 16 channels but 8 are connected.
Vladimir, hi.
The SDK to control settings is here,
https://docs.openbci.com/docs/02Cyton/CytonSDK
Since you are using Brainflow (your previous thread on Matlab live access), then this thread below shows how to send those strings on the SDK document, from Brainflow.
https://openbci.com/forum/index.php?p=/discussion/2703/disable-srb-with-brainflow-on-cyton
The old version of the Cyton Getting Started document, had a section describing how the GUI 'Hardware Settings' page works. See section 4(e).
https://github.com/openbci-archive/Docs/blob/master/Tutorials/01-Cyton_Getting Started_Guide.md
I believe there will eventually be some additions to the current docs to re-insert this discussion on the Settings operation.
https://github.com/OpenBCI/Documentation/issues/16
