Get Heavy Noise with A0~A5 pin
in Cyton
Hi I'm Bongwoo Bak.
I have some problem with my OpenBCI 8-bit board.
I adjust the C++ and INO source code in order to get raw signal with A0~A5 pins.
But in the act of streaming data, I put a wire in A0 (I set A0 as an OUTPUT pin) and the noise get intensify.
How can I do?
Let me try to clarify what you are saying. You are using A0 as a digital output pin. And when you stream output data to that pin from your Arduino program, you are seeing a lot of incoming noise, from the analog input pins A1 through A5? Or are you referring to noise you see on the EEG input channels?
Is it possible you have some kind of ground loops or issues with the grounding of your signals getting intermingled? When you do not output on A0 does the noise stop?
