Windows OpenBCI GUI freezes [resolved]
Hello everyone, I'm kind new here.
I had problem before which was described in https://openbci.com/forum/index.php?p=/discussion/2223/is-my-cyton-broken-non-responsive-after-attempted-firmware-upgrade topic.
I did all steps which was mentioned there as solving options and from first sight it should work well.
My dongle sees cyton well, does the connection and starts the session, but as soon as I try to press start streaming data it just completely freezes.
At the begging I thought that maybe it's because of GUI but after I tried several versions of it nothing changes.
Any suggestions what it could be?
Please share the GUI Console Log here on this thread. This will show what is happening in the background with the GUI side of things.
@retiutut Thank you for response .
If I understood right GUI is making directory and files by itself, so I tried to ''reinstall'' but still have same error.
By reinstall I meant to delete all folders with files in it which belongs to GUI.
So this is result of console log.
I see errors showing that your computer is not allowing the GUI to write to file. Please run as Administrator to allow the GUI and BrainFlow to function properly. Most apps require such permission to save/load any kind of information to/from the hard drive.
Sorry that I didn't mention it before, I have tried to run as Administrator many times, but still have same error.
Otherwise I would not ask for help here
I have solved the problem, by deactivating antivirus program.
But still thank you @retiutut for your help
