Neuromore Studio 1.4.7
nejemianejemia argentina
Hello:
I was trying to test the Neuromore Studio 64 bits Windows Version with the CYTON.
The CYTON works perfect with the OpenBCI_GUI's as well as with OpenVibe aquisition Server.
However, I can not make it to be recognized on Neuromore Studio.
Is there any known change in the protocol that prevent the CYTON to be detected by Neuromore Studio?
I tested Neuromore Studio versions 1.4.4 up to last 1.4.7 with same results. No OpenBCI detected...
Nelson
    In the distant past neuromore had a user support group. That does not appear to exist currently. I did ask Andrew Grosser, the dev who brought neuromore back to life, in July, if a new forum was planned. Got no reply, but he did apparently incorporate one suggestion on the Github page. His email is dioptre at gmail.com. It's appears there are new devs, see right column at,
    https://github.com/neuromore/studio
    This is most active dev, https://github.com/cyberjunk . Andrew is https://github.com/dioptre and may be working on other projects now.
    The serial port protocol that existed when neuromore was developed, is still compatible with current firmware. Many new additions have been made, but the original SDK commands and data stream format should be compatible.
    Clint's website: https://banzhaf.pro/
