Running 2 Cyton on 2 different computers in the same room
I am attempting to run 2 different Cytons on 2 different computers at the same time. But have not yet been able to do so. Can anyone direct me as to how to do it. Thanks
    Curtis, hi.
    First turn on one Cyton and dongle at a time, unplug / turn off the other. Expand the arrow in Section 5, Optional Settings. Then use Get Channel, Change Channel, to move one of the Cytons to another channel. Take a piece of labeling tape and put the channel number on each Cyton and dongle for further reference.
    https://docs.openbci.com/docs/01GettingStarted/01-Boards/CytonGS#5-optional-settings
    If by chance you've previously confused the two dongles (no labels as to which Cyton they belong), then it's possible you may need to swap or do AUTOSCAN. But once the two Cyton/dongles are on separate channels, and labeled, you should be fine.
